02-01-2011, 10:51 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: sri lanka/thailand/maldives Age: 44
Member: 283763 Status: Offline Thanks Meter: 102 | k320 unlock problem cid 50 i know this modle is very old, but i have very big problem, this phone unlock with server credit but still locked. try with test card but still locked, any body have solution for this thanks |
06-23-2011, 16:22 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 LDR:070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D FLASH ID: 897E OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601851058 CERT:RED ACTIVE CID:50 COLOR:RED Model (from GDFS):K320i Brand:Vodafone (PrePay) MAPP CXC article: R4GC012 prgCXC1250682_GENERIC_MA MAPP CXC version: R4GC012 Language Package: VFE_2 CDA article: CDA102728/73 CDA version: R4B Default article: cxc1250690 Default version: R4GC012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:101100000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601851058 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 897E writing "D:\setool\flash\K_xxx\K320\CID50\r4gc012\R4GC012_ 1250682_GENERIC_MA.ssw" CURRENT FLASH FILE CID: 50 SSW uses full hash, hash len is: 6320 Will flash 316 blocks... writing "D:\setool\flash\K_xxx\K320\CID50\r4gc012\R4GC012_ fs_M_East_N_Afr_MA_red_cid50.ssw" CURRENT FLASH FILE CID: 50 SSW uses full hash, hash len is: 2340 Will flash 117 blocks... LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 304 secs. SIGNED MODE (USING SERVER) CFG:101100000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601851058 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM14 PHONE READY TO PROCEED. GOT SEED:00D4E331 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 343 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601851058 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM14 PHONE READY TO PROCEED. GOT SEED:00E6CC33 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 80 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601851058 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM14 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 STARTING BOOTLOADER... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E FOUND VERSION "R4GC012_CXC1250682_GENERIC_MA" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 191 secs. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
