04-02-2009, 15:50 | #1 (permalink) |
Insane Poster Join Date: Jun 2006
Member: 287997 Status: Offline Thanks Meter: 4 | K320i gdfs pramas failed v0.915034/UNI CARD SERIAL: 000**** Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601998657 CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS SETOOL2 CAN'T FIX THAT PHONE Elapsed: 4 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601998657 CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS SETOOL2 CAN'T FIX THAT PHONE Elapsed: 3 secs. RECOVERY MODE STARTED Open COM port OK NEW SECURITY (MARITA RESPIN) PHONE err: 32 (9) loader header not accepted Open COM port OK PROCEDURE WAS STOPPED BY USER Elapsed: 29 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601998657 CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS SETOOL2 CAN'T FIX THAT PHONE Elapsed: 2 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601998657 CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS SETOOL2 CAN'T FIX THAT PHONE Elapsed: 2 secs. file "gdfs.bin" can't be found or opened Elapsed: 0 secs. Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601998657 CERT:RED phone CID not supported in that mode Elapsed: 2 secs. SIGNED MODE (USING SERVER) Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 37 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:356706******** CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 Flash ID check:897E Flash props sent ok writing "D:\SEtool\v0.915034\gdfs_in_ssw_format\db2010\k32 0_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:32 HDR block not accepted,error: 02 Elapsed: 7 secs. SIGNED MODE (USING SERVER) Will write GDFS now. Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:356706***8***CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 21 secs. SIGNED MODE (USING SERVER) Open COM port OK PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 52 secs. SIGNED MODE (USING SERVER) Open COM port OK PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 29 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670**********CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 3 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:3567060*********** CERT:RED FLASH CID:51 COLOR:RED setGDFS_params failed failed to setup GDFS SETOOL2 CAN'T FIX THAT PHONE Elapsed: 7 secs. PLZ HELP ITS URGENT THIS HANDSET I UNLOCKED VIA TP LAST WEAK ITS OK 100% BUT NOW THIS PROBLEM WHAT I DO THANKS |
K320i gdfs pramas failed | vijaykumarmehta | SETool2 | 2 | 04-03-2009 03:56 |
k320i gdfs fail, cruiser expert please teach me | SURD ENT. | Cruiser Suite | 2 | 11-21-2008 08:56 |
K320i GDFS failed | luqmaan751 | SETool2 | 9 | 08-08-2008 18:36 |
k320i gdfs needed | Jhay-r | Universalbox | 9 | 01-05-2008 03:52 |
