03-06-2011, 05:50 | #1 (permalink) |
Banned Join Date: May 2008
Member: 783336 Status: Offline Thanks Meter: 21 | k510 how to solve this FLASH CID: 0051 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35469101773315 CERT:BROWN FLASH CID:51 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 79 secs. |
03-06-2011, 05:58 | #2 (permalink) |
Banned Join Date: Nov 2010 Location: where we take time for read Age: 38
Member: 1440240 Status: Offline Sonork: JiBriL DcTeAm Thanks Meter: 116 | Solve your probleme with this methode sure 100% : http://forum.gsmhosting.com/vbb/f473...unlock-822592/ |
03-06-2011, 06:20 | #3 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | i try this but no luck....K510 cid 50 perform reset procedure CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select K510 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. add to firmware area SeTool\gdfs_in_ssw_format\db2010\k510_gdfs_in_ssw_ format.ssw 8. add to firmware area Setool\SeTool\eroms\db2010\db2012_erom_cid50.ssw 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings |
03-06-2011, 14:07 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | RESET on SE TAB Bro w/SIGNMODE on SETTINGS TAB FLASH GDFS@EROMS on EMPTY FILL REPAIR TAB Flash Main@FS,,,,,,,,w/SIGNMODE@CUSTOMIZED on SETTINGS,, DONE Br,. Rhyan777 |
03-08-2011, 11:51 | #6 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | RUNNING v 1.01/UNI CARD SERIAL 00016544 USBFLASH DRIVER VERSION 02.02.00.05 Found 2 FTDI device(s). UFS #16792 READY SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 4 secs. Found 2 FTDI device(s). UFS #16792 READY SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:1CD8CECB218083691530CCBC P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35469101773315 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 9 secs. i dont have erom file for k510..plz post here |
03-08-2011, 12:09 | #7 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | if i write only gdfs file than this error comes..... PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35469101773315 CERT:BROWN can't get packet start. ldr_on_ldr prologue error (00) Elapsed: 36 secs. |
03-08-2011, 15:22 | #8 (permalink) |
Major Poster Join Date: Apr 2006
Member: 257834 Status: Offline Thanks Meter: 3 | do You used 1.104?? I try todey this: BUT ver 1.03 (on 1.104 sometimes not work) How to repair GDFS Instruction for any phone. I try on my K770 1. Go to "EMPTY FILL & REPAIR" tab - set actulay Flash CID, on Settings check "SINGED MODE" and press RECOVERY with 2+5 2. On "EMPTY FILL & REPAIR" tab add GDFS file in SSW format, on Settings "SINGED MODE" must be NOT checked, press FLASH (2+5) 3. On "EMPTY FILL & REPAIR" tab add EROM file (file with actualy CID or CID who we be flash it), "SINGED MODE" must be NOT checked, press FLASH (2+5) 4. Now phone is repaired 5. If phone dont work go to "SONYERICSSON" tab , add flash file , on Settings check SINGED MODE & COMPLETE PHONE AFTER FLASH, and FLASH IT. ( with C key ) Phone 100% work |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
