i try to flash the unit but this error occurs..
SIGNED MODE (USING SERVER).
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901922931 CERT:N/A
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005006 0
Flash ID check:897E
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed (1D)
loader GDFS startup failed, that is fatal
Elapsed: 15 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
set_gdfs_props failed, exiting
PROCEDURE WAS STOPPED BY USER
Elapsed: 39 secs.
Open COM port OK
Speed:921600
FAILED TO SETUP PHONE
Elapsed: 23 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
writing D:\SE TOOL\Flashfile\K530\R6BC002_1250912_GENERIC_NC.ssw
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is:9200
Will flash 460 blocks...
SSW loading returns:0
writing D:\SE TOOL\Flashfile\K530\R6BC002_FS_TELEF_GEN_NC_RED_CI D52.ssw
SSW uses full hash, hash len is:2900
Will flash 145 blocks...
Elapsed: 663 secs.
so i decided to make it in TP procedure..
TESTPOINT REPAIR STAGE #1 STARTED
Open COM port OK
Speed:921600
PREPARING...
ATTACH TP #1 AND PRESS "READY"
RELEASE TP #1 AND PRESS "READY"
TP #1 LOOKS OKAY
DONE
Elapsed: 36 secs.
TESTPOINT REPAIR STAGE #2 STARTED
Open COM port OK
Speed:921600
ATTACH TP #2 AND PRESS "READY"
Trying to launch embedded bootloader...
TP #2 LOOKS OKAY
RELEASE TP #2 AND PRESS "READY"
embedded flashloader not responds !
Elapsed: 26 secs.
Open COM port OK
Speed:921600
TP #2 INCORRECT OR STAGE #1 NOT EXECUTED
Elapsed: 31 secs.
Open COM port OK
Speed:921600
Elapsed: 74 secs.
Open COM port OK
Speed:921600
TP #2 LOOKS OKAY
INT LDRB2020_PRELOADER_FOR_SETOOL2
WRITING EROM...
DONE
Elapsed: 21 secs.
since i dont have a microscope to see the pin on tp, i decide to pull up the flash i.c and make two jumper (tp1 and tp2)
successful!
heres the logs now in flashing..
Br,
SAINT
