09-03-2008, 07:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | k530 strange problem SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35780401749267 CERT:N/A FLASH CID:52 COLOR:RED Model:K530i Brand:Generic MAPP CXC article: R6BC002 prgCXC1250915_HONG_KONG_NC MAPP CXC version: R6BC002 Language Package:HONG_KONG CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1250959 Default version: R6BC002 PROVIDER: 000-00 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE NOT PRESENT "R6BC002_CXC1250915_HONG_KONG_NC.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 6 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35780401749267 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 5 secs. |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-21-2010 09:01 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
k530 mic problem | tshcom | Sony Ericsson Hardware Repair | 4 | 08-10-2009 23:55 |
K530 Unlock Problem!!!! | scebic | MT-BOX | 0 | 01-04-2008 16:09 |
