09-22-2009, 17:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | Setool a2 patch.... The Lazer says "no discursion about a2 patch on support forum"...but here we can!! How to apply patch ??? thx |
The Following User Says Thank You to edcentec For This Useful Post: |
09-23-2009, 00:53 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | Quote:
IF YOUR PHONE IS CERTIFICATE RED PLEASE START FROM STEP 1. 1. Start Up SeTool and Select "Signed Mode" and "Alt Bypass" click domain as brown 2. Press Unlock. 3. Remove your battery and reinsert it. 4. Connect holding 2+5 buttons down. 5. you phone will be unlocked and have a brown certificate ready to patch. A2 Uploader Method 6. Open up A2 Uploader. 7. Where it says "MISC" browse for the VKP patch you want. 8. Now where it says "E" click it and the patch should open up in notepad. 9. Add this line to the beginning of the patch. Code: ;PatchFile=/boot/phone_app.cxc 10. Hit CTRL + S. Or save it. (This can be done before step 15.) 11. Now on A2 Uploader click "WRITE SCRIPT". 12. Connect your phone as usual, but this time hold down "c". If your phone's power button is "c" then connect with 2+5. 13. Wait. A2 Uploader takes a long time. Even with small patches. When a popup comes up click "NO". Wait some more. 14. After it says, "ELAPSED: xx secs." it has ended, and you can unplug your phone. That's it! You have successfully patched your A2 CID 52 phone! Now to keep patching you only need to start from step 6. Hope this helps Thanks B.u Mobiles | |
The Following 8 Users Say Thank You to BuMobiles For This Useful Post: |
09-23-2009, 01:41 | #3 (permalink) | ||
Banned Join Date: Feb 2007
Member: 447548 Status: Offline Thanks Meter: 83 | Quote:
if yes, how ? | ||
09-23-2009, 17:21 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | That should be imei patching, otherwise doesn't make any sense, however thread starter i think was refering to patch unlocking A2 phones, luck |
09-23-2009, 23:11 | #7 (permalink) |
Member: 503346 Status: Offline Thanks Meter: 2,582 | Follow the steps to patch the cxc file with the phone then apply any vkp patch to the phone with the correct options ticked Thanks B.u Mobiles |
The Following User Says Thank You to BuMobiles For This Useful Post: |
09-27-2009, 23:18 | #14 (permalink) |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | if anyone got an a2 phone we can test over teamviewer... ill send all the progs but its test so must be one that has no value that if it dies oh well .. its test phone |
SETOOL A2 Unlocking Release | shahzaadbutt | SETool2 | 35 | 01-25-2013 17:47 |
Setool A2 and db2020 unlock works instant! | minakostic | Universalbox | 4 | 03-25-2008 02:54 |
SETOOL A2 Successfully Unlock | rajtelecom | SETool2 | 8 | 01-28-2008 06:45 |
SETOOL A2 Unlocking :: SETOOL Logs In Very Cheap Price | shahzaadbutt | Main Sales Section | 0 | 01-13-2008 10:34 |
SETOOL A2 Unlocking :: SETOOL Logs In Very Cheap Price | shahzaadbutt | Main Sales Section | 0 | 12-20-2007 09:22 |
