Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 03-13-2010, 16:13   #1 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
Question k550 flash problem log hre help need urgent
PHONE STATE: "RETAIL"
FLASH CID: 0053
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35491101029959 CERT:RED
FLASH CID:53 COLOR:RED
PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID:2019
writing "F:\Flashing Files\k550\r6bc002 cid53\R6BC002_1250669_GENERIC_LI.ssw"
CURRENT FLASH FILE CID:53
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "F:\Flashing Files\k550\r6bc002 cid53\r6bc002_fs_baltic_li_red_cid53.ssw"
SSW uses full hash, hash len is: 3460
Will flash 173 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
can't get packet start.
FS startup failed,error is 00 [ 0]
loader fs startup failed, that is fatal
Elapsed: 526 secs.
Old 03-13-2010, 16:19   #2 (permalink)
william274's Avatar
Member: 690249
Thanks Meter: 52
You phone is cid53 you shure put fs cid53
check you fs if cid53 friend
or battery is low try with battery full
BR,
Old 03-13-2010, 16:23   #3 (permalink)
Member: 1149013
Thanks Meter: 247
Question
BR,
battery full charge & file fs is comfirm cid 53
and other soluation bro .................
Old 03-13-2010, 16:26   #4 (permalink)
pavithra_uk's Avatar
Member: 1142667
Thanks Meter: 16
make sure correct files (CID53). or flash file may be coruppted.
Old 03-13-2010, 16:39   #5 (permalink)
Member: 1149013
Thanks Meter: 247
i try 2 change files but alsow i fasce this problem ???
Old 03-14-2010, 08:41   #6 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
then DO Reset Operation Mate.
Old 03-14-2010, 09:05   #7 (permalink)
Rhyan777's Avatar
Member: 893209
Thanks Meter: 274
RESET The PHONE..Use LATEST VERSION its FREE MATE..!!
Br,.
Rhyan777
Old 03-14-2010, 12:16   #8 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
poste full log plz i think you boot your phone with 2+5 !!!
Old 03-14-2010, 15:41   #9 (permalink)
Member: 1149013
Thanks Meter: 247
Question
yes i boot with 2+5 button
Old 03-14-2010, 16:03   #10 (permalink)
Member: 1149013
Thanks Meter: 247
Question flash problem after use C button same problem
v0.915050/UNI
CARD SERIAL: 00076646
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
CFG:100110000000
ChipID:9900,EMP protocol:0301
erom_readvar: error reading unit 1/851
error while reading SIMLOCK SIGNATURE unit
phone was tampered with other software
SECURITY UNITS CAN'T BE READ !
DAMAGED FIRMWARE,GDFS OR EMPTY PHONE
CONTINUE ON YOUR OWN RISK
FLASH CID: 0053
Speed:921600
FLASH ID:2019
Model (from GDFS):K550i
MAPP CXC article: R6BC002 prgCXC1250669_GENERIC_LI
MAPP CXC version: R6BC002
Language Package: ORANGE_GEN
CDA article: CDA102568/1
CDA version: R2A
Default article: cxc1250671
Default version: R6BC002
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
Elapsed: 8 secs.
CFG:100110000000
FLASH CID: 0053
Speed:921600
FLASH ID:2019
writing "F:\Flashing Files\k550\r6bc002 cid53\r6bc002_fs_orange_gen_li_red_cid53.ssw"
SSW uses full hash, hash len is: 3700
Will flash 185 blocks...
Elapsed: 533 secs.
Old 03-14-2010, 16:49   #11 (permalink)
Member: 591880
Thanks Meter: 561
plz try to flash it with COM and poste LOG
Old 03-14-2010, 16:57   #12 (permalink)
Member: 591880
Thanks Meter: 561
i think you can flash it with COM but with USB you have this erreur
if you need to flash it with USB do this :
using com/ufs write next script in SIGNED MODE (check ONLY "USE SIGNED MODE" on settings)
gdfswrite:0001085144554D4D5944415441
Old 03-14-2010, 23:22   #13 (permalink)
Registered User
Member: 493205
Sonork: 100.1581647
Thanks Meter: 526
first ...try to flash phone with main flash only and in setting tap select (signe mode & costomazation)
if not solve ..........recovery .....gdfs.ssw ....erom... unlock ............
Old 03-15-2010, 01:13   #14 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
@ Master software :
Your answer is here : NO Customise ERROR FS Startup failed error is 00 [ 0]
Max_B
Old 03-15-2010, 10:25   #15 (permalink)
Member: 1149013
Thanks Meter: 247
Question
Originally Posted by Max_B View Post
@ Master software :
Max_B
v0.915050/UNI
FILE RECOGNIZED AS CUSTOMIZATION PACKAGE.
MODEL:K550im
CDA: CDA102743/612
CDA REV: R6A
VARIANT:I_MODE_2
LANGUAGE: EN BG EL RO
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:2019
CDA version: R2A
PROVIDER: 000-00
Elapsed: 73 secs.
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:2019
writing "F:\Flashing Files\k550 im'\R3B021_cxc1250592_FOTA_UA_MARIKA_CID53_RED.ssw "
SSW uses full hash, hash len is: 80
Will flash 4 blocks...
writing "F:\Flashing Files\k550 im'\R6BC002_1250791_GENERIC_LM.ssw"
writing "F:\Flashing Files\k550 im'\r6bc002_fs_i_mode_1_lm_red_cid53.ssw"
SSW uses full hash, hash len is: 3380
Will flash 169 blocks...
Elapsed: 530 secs.
after flash fota+main+fs5
3 post result
k550 flash problem any body help me saeed ahmed Sony Ericsson 1 03-13-2010 15:52
3220 flashing problem-logs posted help me zone2 UFS - Pro 4 01-07-2008 17:23
6610 flashing problem-logs posted-help me zone2 Nokia Hardware & Hardware Repair 2 11-13-2007 10:55
Page generated in 0.24665 seconds with 9 queries
