01-08-2009, 07:13 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india Age: 39
Member: 650853 Status: Offline Thanks Meter: 118 | k550 flashing problem ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301652513 CERT:N/A FLASH CID:51 COLOR:RED Model:K550i MAPP CXC article: R1JD001 prgCXC1250669_GENERIC_LI MAPP CXC version: R1JD001 Language Package:M_EAST_N_AFR CDA article: CDA102743/117 CDA version: R1A Default article: cxc1250671 Default version: R1JD001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SEARCH:C:\Program Files\setool\files\k550\cid 51\R1JD001_1250669_GENERIC_LI.ssw "R1JD001_CXC1250669_GENERIC_LI" CREATED Elapsed: 8 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301652513 CERT:N/A FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok bypassing security... server step1 error:No server found. unlock failed, that is fatal Elapsed: 14 secs. help me |
01-08-2009, 09:00 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Hello try this Click on Signed Mode ( use server for bypass csca) in setting tab then complete phone and also unlock after flash tick these option then try and post result Thanxs |
01-09-2009, 06:38 | #3 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Libya-Tripoly
Member: 565230 Status: Offline Thanks Meter: 22 | use latest setool2 if the phone locked ,do like mujahid_ali sayed if not,just on sitting tab check only (signed mode +complete phone ) then flash phone normaly..... Last edited by GsmOwar; 01-09-2009 at 06:44. |
k550 flash problem log hre help need urgent | Master Software | SETool2 | 24 | 05-28-2010 15:12 |
k550 flash problem any body help me | saeed ahmed | Sony Ericsson | 1 | 03-13-2010 15:52 |
k550 flash problem | billa2008 | SETool2 | 4 | 03-05-2010 23:29 |
K550 flashing problem | mihaitza74 | SETool2 | 3 | 11-22-2008 10:44 |
k550 flash problem | germany | Sony Ericsson Hardware Repair | 1 | 10-02-2008 13:09 |
