06-03-2010, 17:42 | #1 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 784526 Status: Offline Thanks Meter: 12 | k550i flashing problem I WANT TO FLASH K550i SONY ERICSSON WITH SETOOL BOX. ACTUALLY IT IS CID 53. AFTER FLASHING. NOW IT IS SHOWING LIKE THIS RUNNING v 1.01/UNI CARD SERIAL XXXXXXXX CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35934601854416 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 10 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35934601854416 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\vyshnavi\My Documents\Downloads\k550.latest\K550_R6BC002_FS_BA LTIC_RED53\K550_R6BC002_MAIN_GENERIC_LI_RED53.mbn" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 4 secs. I WANT TO FLASH IT. SO KINDLY GIVE THE PROPER SOLUTION FOR THIS PROBLEM. MOST URGENT. WHICH FILES I HAVE TO USE AND FROM WHERE I WILL GET THAT FLASH FILES TO DOWNLOAD. THANKS IN ADVANCE |
06-03-2010, 17:52 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
06-04-2010, 08:52 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
please check FAQ for details. try again with fully charred battery and good cable if still same check in hardware BR | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
