Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 08-17-2009, 10:15   #1 (permalink)
Member: 632070
k550i fs startup failed
k550i cid 51
can't get packet start.
FS startup failed,error is 00 [ 0]
loader fs startup fa
see my log
please helpv0.915040/UNI
CARD SERIAL: 00054939
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
CFG:10001000000000
ChipID:9900,EMP protocol:0301
Speed:115200
Flash ID check:2019
Flash props sent ok
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301654176 CERT:N/A
FLASH CID:51 COLOR:RED
Model (from GDFS):K550i
Brand:Generic
MAPP CXC article: R1JD001 prgCXC1250670_CHINA_LI
MAPP CXC version: R1JD001
Language Package: APAC
CDA article: CDA102568/1
CDA version: R2A
Default article: cxc1250671
Default version: R1JD001
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed: 6 secs.
CFG:10001000000000
Speed:115200
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
writing "D:\se flash files\k550i\cid 51\red\r1jd001\R1JD001_1250670_CHINA_LI.ssw"
CURRENT FLASH FILE CID:51
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
SSW loading returns:0
writing "D:\se flash files\k550i\cid 51\red\r1jd001\R1JD001_FS_APAC_LI_RED_CID51.ssw"
SSW uses full hash, hash len is: 3780
Will flash 189 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader fs startup failed, that is fatal
Elapsed: 4050 secs.
CFG:10001100000000
Speed:115200
Can't load ID loader !
Elapsed: 13 secs.
CFG:10001100000000
Speed:115200
Flash ID check:2019
Flash props sent ok
Brand:Generic
CDA version: R2A
PROVIDER: 000-00
Elapsed: 6 secs.
ALTERNATIVE SECURITY BYPASS ENABLED
PRELOADER SECURITY BYPASS ENABLED
CFG:10110000000000
Processing script "D:\se flash files\k550i\cid 51\red\r1jd001\fs manager.txt"...
Speed:115200
Flash ID check:2019
Flash props sent ok
Old 08-17-2009, 10:27   #2 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
check battery must be fully charge and cable
then flash again
Old 08-17-2009, 10:28   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
then flash again
Cannot flash K800i "loader fs startup failed, that is fatal"???? svchost SETool2 5 01-17-2009 01:11
K700I DEAD-''loader fs startup failed, that is fatal''-WROTE GDFS-NO SCOPE-HELP zonetrichur Sony Ericsson 4 12-08-2008 01:15
K800i loader fs startup failed, that is fatal? svchost SETool2 6 08-28-2008 16:58
k310i loader fs startup failed, that is fatal Chandreshswami SETool2 2 07-29-2008 09:17
Page generated in 0.21295 seconds with 11 queries
