Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 08-06-2008, 07:24   #1 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
>>> K550i gdfs damaged successfully repaired <<<
8/6/2008 2:11:45 PM v0.914037/UNI
8/6/2008 2:11:45 PM CARD SERIAL: >>> keaelite <<<
8/6/2008 2:11:45 PM Loaded 51 flash descriptors
8/6/2008 2:11:45 PM Connecting to UFS...
8/6/2008 2:11:45 PM Found 2 FTDI device(s).
8/6/2008 2:11:46 PM UFS #74033 READY
8/6/2008 2:11:59 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:12:02 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:12:02 PM Speed:921600
8/6/2008 2:12:03 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:12:03 PM FLASH CID:52 COLOR:RED
8/6/2008 2:12:04 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:12:04 PM PREPARING...
8/6/2008 2:12:10 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:12:31 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:12:33 PM TP #1 LOOKS OKAY
8/6/2008 2:13:08 PM NOT EXPECTED ANSWER
8/6/2008 2:13:08 PM Elapsed: 68 secs.
8/6/2008 2:13:14 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:13:16 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:13:16 PM Speed:921600
8/6/2008 2:13:17 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:13:17 PM FLASH CID:52 COLOR:RED
8/6/2008 2:13:18 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:13:18 PM PREPARING...
8/6/2008 2:13:25 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:14:27 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:14:28 PM TP #1 INCORRECT
8/6/2008 2:14:32 PM loader refused shutdown, remove and insert battery !
8/6/2008 2:14:33 PM PROCEDURE WAS STOPPED BY USER
8/6/2008 2:14:33 PM Elapsed: 78 secs.
8/6/2008 2:14:33 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:14:34 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:14:34 PM Speed:921600
8/6/2008 2:14:35 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:14:35 PM FLASH CID:52 COLOR:RED
8/6/2008 2:14:36 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:14:36 PM PREPARING...
8/6/2008 2:14:43 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:14:51 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:14:53 PM TP #1 INCORRECT
8/6/2008 2:14:54 PM Elapsed: 20 secs.
8/6/2008 2:14:59 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:15:01 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:15:01 PM Speed:921600
8/6/2008 2:15:02 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:15:02 PM FLASH CID:52 COLOR:RED
8/6/2008 2:15:03 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:15:03 PM PREPARING...
8/6/2008 2:15:10 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:15:55 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:15:58 PM TP #1 INCORRECT
8/6/2008 2:16:07 PM loader refused shutdown, remove and insert battery !
8/6/2008 2:16:07 PM PROCEDURE WAS STOPPED BY USER
8/6/2008 2:16:07 PM Elapsed: 67 secs.
8/6/2008 2:16:15 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:16:17 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:16:17 PM Speed:921600
8/6/2008 2:16:18 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:16:18 PM FLASH CID:52 COLOR:RED
8/6/2008 2:16:19 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:16:19 PM PREPARING...
8/6/2008 2:16:26 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:16:39 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:16:43 PM TP #1 INCORRECT
8/6/2008 2:16:55 PM loader refused shutdown, remove and insert battery !
8/6/2008 2:16:55 PM PROCEDURE WAS STOPPED BY USER
8/6/2008 2:16:55 PM Elapsed: 40 secs.
8/6/2008 2:16:56 PM TESTPOINT REPAIR STAGE #1 STARTED
8/6/2008 2:16:57 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:16:57 PM Speed:921600
8/6/2008 2:16:58 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:16:58 PM FLASH CID:52 COLOR:RED
8/6/2008 2:16:59 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
8/6/2008 2:16:59 PM PREPARING...
8/6/2008 2:17:05 PM ATTACH TP #1 AND PRESS "READY"
8/6/2008 2:17:08 PM RELEASE TP #1 AND PRESS "READY"
8/6/2008 2:17:09 PM TP #1 LOOKS OKAY
8/6/2008 2:17:18 PM DONE
8/6/2008 2:17:18 PM Elapsed: 22 secs.
8/6/2008 2:17:42 PM TESTPOINT REPAIR STAGE #2 STARTED
8/6/2008 2:17:44 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:17:44 PM Speed:921600
8/6/2008 2:17:45 PM ATTACH TP #2 AND PRESS "READY"
8/6/2008 2:18:21 PM Trying to launch embedded bootloader...
8/6/2008 2:18:21 PM TP #2 LOOKS OKAY
8/6/2008 2:18:21 PM RELEASE TP #2 AND PRESS "READY"
8/6/2008 2:18:23 PM INT LDRB2020_PRELOADER_FOR_SETOOL2
8/6/2008 2:18:27 PM WRITING EROM...
8/6/2008 2:18:30 PM DONE
8/6/2008 2:18:31 PM Elapsed: 49 secs.
8/6/2008 2:19:04 PM SIGNED MODE (USING SERVER).
8/6/2008 2:19:04 PM ALTERNATIVE SECURITY BYPASS ENABLED.
8/6/2008 2:19:06 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:19:06 PM Speed:921600
8/6/2008 2:19:07 PM Flash ID check:2019
8/6/2008 2:19:07 PM Flash props sent ok
8/6/2008 2:19:07 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:19:07 PM FLASH CID:49 COLOR:BROWN
8/6/2008 2:19:08 PM
8/6/2008 2:19:08 PM Model:K550i
8/6/2008 2:19:08 PM Brand:Customized
8/6/2008 2:19:08 PM MAPP CXC article: R6BC002 prgCXC1250670_CHINA_LI
8/6/2008 2:19:08 PM MAPP CXC version: R6BC002
8/6/2008 2:19:08 PM Language Package:APAC
8/6/2008 2:19:08 PM CDA article: CDA102743/166
8/6/2008 2:19:08 PM CDA version: R2A
8/6/2008 2:19:09 PM Default article: cxc1250671
8/6/2008 2:19:09 PM Default version: R6BC002
8/6/2008 2:19:09 PM PROVIDER: 000-00
8/6/2008 2:19:09 PM SIMLOCKS NOT DETECTED
8/6/2008 2:19:09 PM
8/6/2008 2:19:09 PM SEARCH:G:\flash\k550\cid52\r6bc002\R6BC002_1250669 _GENERIC_LI.ssw.bin
8/6/2008 2:19:09 PM can't open file "G:\flash\k550\cid52\r6bc002\R6BC002_1250669_GENER IC_LI.ssw.bin"
8/6/2008 2:19:09 PM SEARCH:G:\flash\k550\cid52\r6bc002\R6BC002_FS_RUSS IA_LI_RED_CID52.ssw.bin
8/6/2008 2:19:09 PM can't open file "G:\flash\k550\cid52\r6bc002\R6BC002_FS_RUSSIA_LI_ RED_CID52.ssw.bin"
8/6/2008 2:19:09 PM RESTORATION FILE NOT PRESENT
8/6/2008 2:19:09 PM "R6BC002_CXC1250670_CHINA_LI"
8/6/2008 2:19:09 PM YOU MUST PERFORM FULL FLASHING
8/6/2008 2:19:09 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
8/6/2008 2:19:09 PM
8/6/2008 2:19:09 PM Elapsed: 5 secs.
8/6/2008 2:20:10 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:20:10 PM Speed:921600
8/6/2008 2:20:11 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:20:11 PM FLASH CID:49 COLOR:BROWN
8/6/2008 2:20:13 PM LDR:060721 1021 DB2020_SERVICE_LOADER
8/6/2008 2:20:14 PM Flash ID check:2019
8/6/2008 2:20:14 PM Flash props sent ok
8/6/2008 2:20:14 PM writing F:\SETool\v.0914037\gdfs_in_ssw_format\db2020\k550 _gdfs_SSW.ssw
8/6/2008 2:20:15 PM CURRENT FLASH FILE CID:49
8/6/2008 2:20:15 PM SSW uses complete hash, hash len is:640
8/6/2008 2:20:15 PM Will flash 32 blocks...
8/6/2008 2:20:49 PM SSW loading returns:0
8/6/2008 2:20:49 PM Setting up GDFS...
8/6/2008 2:20:50 PM OTP WRITE NOT EXECUTED.
8/6/2008 2:20:50 PM Writing simlocks...
8/6/2008 2:20:50 PM ALL UNLOCK/LOCK CODES SET TO "53206577"
8/6/2008 2:20:50 PM Signing...
8/6/2008 2:20:50 PM control keys complete.
8/6/2008 2:20:52 PM full sig complete.
8/6/2008 2:20:54 PM Elapsed: 44 secs.
8/6/2008 2:21:23 PM SIGNED MODE (USING SERVER).
8/6/2008 2:21:23 PM ALTERNATIVE SECURITY BYPASS ENABLED.
8/6/2008 2:21:25 PM ChipID:9900,EMP protocol:0301
8/6/2008 2:21:25 PM Speed:921600
8/6/2008 2:21:26 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:35934601507294 CERT:N/A
8/6/2008 2:21:26 PM FLASH CID:49 COLOR:BROWN
8/6/2008 2:21:29 PM LDR:060721 1021 DB2020_SERVICE_LOADER
8/6/2008 2:21:29 PM Flash ID check:2019
8/6/2008 2:21:29 PM Flash props sent ok
8/6/2008 2:21:29 PM writing F:\SETool\v.0914037\eroms\DB2020EROM_CNV_RED52_BRO WN_CID49_DB2020.ssw
8/6/2008 2:21:30 PM CURRENT FLASH FILE CID:49
8/6/2008 2:21:30 PM SSW uses complete hash, hash len is:40
8/6/2008 2:21:30 PM Will flash 2 blocks...
8/6/2008 2:21:32 PM SSW loading returns:0
8/6/2008 2:21:35 PM Elapsed: 11 secs.
br
keaelite
Old 10-02-2008, 15:12   #2 (permalink)
raffazila's Avatar
Member: 64957
can someone tell me where to fix the needle in k550 as testpoint.everywhere i see video for the procedure to repair gdfs.but give me clear picture or video for the testpoint.i cant find any points on the corner of the ic.thank you.
Old 11-17-2008, 15:17   #3 (permalink)
Member: 304933
Sonork: 100.1618191
i have a same problem
Old 11-17-2008, 22:05   #4 (permalink)
inside-d-saul's Avatar
Member: 581626
for that it is better if you have microskop brother bez Tp are very small .
Tp for K550 and some other phones here:
http://rs260.rapidshare.com/files/12...Testpoints.rar
>>> My X6-2 Successfully Repaired By SMTI <<< zeel_zeel SMTi 5 04-08-2009 22:35
>>> K610i damaged GDFS successfully repaired <<< keaelite SETool2 19 10-08-2008 09:01
Go to first new post >>> K550i gdfs damaged successfully repaired <<< ayhen42 SETool2 1 08-06-2008 10:06
>>> another K800i gdfs damaged successfully repaired <<< keaelite SETool2 2 07-18-2008 10:18
>>> K810i GDFS damage repaired done <<< keaelite SETool2 8 07-09-2008 15:56
Page generated in 0.35673 seconds with 11 queries
