06-25-2013, 17:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 432765 Status: Offline Thanks Meter: 65 | k550i problem need help SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: 9900, EMP protocol: 0301 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701872750 ACTIVE CID: 52 COLOR: RED can't get packet start. PROCEDURE WAS STOPPED BY USER packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 54 secs. |
06-26-2013, 19:15 | #2 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | GDFS damgae. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area proper gdfs in ssw format 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
