Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 03-15-2010, 13:54   #1 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1601130
k550i red blinking repair sucsess by v1.0
RUNNING v1.0/UNI
CARD SERIAL 00125832
USBFLASH DRIVER VERSION 02.02.00.05
CFG:000000000000
ChipID:9900,EMP protocol:0301
Speed:115200
FLASH ID: 2019
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701xxxxxx CERT:N/A
FLASH CID:52 COLOR:RED
SCRC READ FAILURE
Elapsed: 22 secs.
SIGNED MODE (USING SERVER)
CFG:100000000000
RESET MODE STARTED
Speed:921600
RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
FLASH ID: 2019
GOT SEED:018A241E2380317115B07812
P96 AUTH PASSED
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
Elapsed: 20 secs.
br.
hanif007
Old 03-16-2010, 07:32   #2 (permalink)
Member: 71502
Originally Posted by hanif007 View Post
RUNNING v1.0/UNI
CFG:000000000000
Speed:115200
FLASH ID: 2019
SCRC READ FAILURE
Elapsed: 22 secs.
CFG:100000000000
RESET MODE STARTED
Speed:921600
FLASH ID: 2019
P96 AUTH PASSED
Elapsed: 20 secs.
br.
hanif007
PL. GUIDE IN DETAILS
FRIST WHICH OPTION SELECT
PL. HELP
w580i red light blink??????
v0.915043/UNI
CARD SERIAL: 0000****
Loaded 51 flash descriptors
CFG:10001000000000
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100144115 CERT:N/A
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
FLASH ID check:897E
Flash props sent ok
writing "D:\w580 cid52\R8BE001_1123362_GENERIC_LA.ssw"
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
SSW loading returns:0
writing "D:\w580 cid52\R8BE001_FS_HONG_KONG_LA_RED_CID52.ssw"
SSW uses full hash, hash len is: 4260
Will flash 213 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed,error is 04 [1D]
loader GDFS startup failed, that is fatal
Elapsed: 676 secs.
Old 03-16-2010, 08:09   #3 (permalink)
xerraco's Avatar
Member: 890926
Its on Sticky Thread Mate....Here
1. go to emptyboard tab
2. select proper model
3. on settings, check "signed mode"
4. press recovery
5. after succeful recovery
6. on settings uncheck all
7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step
8. add to firmware area proper EROM (EROM CID >= OTP CID)
9. press flash
10. if needed,reflash phone on usual semc tab with needed settings.
I
Old 03-16-2010, 08:17   #4 (permalink)
Member: 71502
4. press recovery
9. press flash
I
CFG:000000000000
RECOVERY MODE STARTED
PROCEDURE WAS STOPPED BY USER
Elapsed: 57 secs.
CFG:100000000000
RESET MODE STARTED
Speed:115200
FLASH ID: 897E
GOT SEED:4A9F38E02380072C00302F23
P96 AUTH PASSED
Elapsed: 72 secs.
but mobile not on
if flashing must????
Old 03-16-2010, 10:45   #5 (permalink)
xerraco's Avatar
Member: 890926
After Successful Reset you need to Flash needed GDFS in SSW Format & EROM, then Full flash.
Old 03-19-2010, 04:19   #6 (permalink)
Member: 172261
i've same problem but after try still same
4. press recovery
9. press flash
Sony Ericsson K550i RED Blink Repair Done By Setool3 Sahil2007 SETool2 10 04-06-2009 23:12
k550i red blink done nadim electro SETool2 0 02-19-2009 07:52
Sony Ericsson K800i RED Blink Repair Done By Setool3 Sahil2007 SETool2 0 11-24-2008 18:12
k550i red blink ponix SETool2 6 08-06-2008 17:50
z610i red blink repaired by dbss alfox DreamBox 2 06-14-2008 02:20
Page generated in 0.39336 seconds with 11 queries
