03-13-2010, 10:22 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1160311 Status: Offline Thanks Meter: 0 | K608 red flashing after unlock pls help The handset was originally red 37 and is now brown 37 - i think i need to recover cert back to red but not sure how to do this on setool. Here is log - but this was from second unlock so now certs are brown PHONE STATE: "DEVELOPER" FLASH CID: 0037 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:37 PAF:1 IMEI:35684100xxxxxxxx CERT:BROWN LDR:040422 0732 LLECXC1325413_CERTLOADER R3L LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z FLASH ID:890D Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "60620324" SIGNING... Unlock FINISHED Elapsed: 16 secs. many thanks in advance |
08-30-2010, 10:03 | #3 (permalink) |
Freak Poster Join Date: Sep 2009 Location: No location
Member: 1120374 Status: Offline Thanks Meter: 67 | PHONE STATE: "DEVELOPER" FLASH CID: 0037 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:37 PAF:1 IMEI:3568********* CERT:BROWN LDR:040422 0732 LLECXC1325413_CERTLOADER R3L LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z FLASH ID: 890D Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "52477313" SIGNING... Unlock FINISHED Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0037 Speed:921600 BAUDRATE DECREASED RESET:070703 1102 NPACXC125880_DB2000_CERTRESETLOADER_P4D FLASH ID: 890D GOT SEED081EA871580EA7105A06620 P96 AUTH PASSED OTP: LOCKED:1 CID:37 PAF:1 IMEI:35684********** CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 23 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:37 PAF:1 IMEI:3568********* CERT:BROWN FLASH ID: 890D SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\Documents and Settings\GSM\Desktop\SE-tool\gdfs_in_ssw_format\db2000\k600_gdfs_in_ssw_fo rmat.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 16 Will flash 16 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "28438630" SIGNING... Elapsed: 46 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:37 PAF:1 IMEI:3568********** CERT:BROWN FLASH ID: 890D SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\Documents and Settings\GSM\Desktop\SE-tool\eroms\db2000\k600_k608_v600_new_erom.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "26702217" SIGNING... Elapsed: 22 secs. |
The Following User Says Thank You to ATUGA For This Useful Post: |
kill my phone after unlock... pls help | senkron24 | BB5BOX | 4 | 02-16-2008 09:30 |
e380 dont work on 900 after unlock pls help nead | bulid | Motorola P2k | 0 | 08-18-2004 00:59 |
Q105 Keeps on charging after unlock, pls help | Hanukkah | Trident/AGERE Platform | 4 | 03-09-2003 12:26 |
dead c28 v61 after unlocking pls help ! | balanel | x1x to x45/x50 | 14 | 09-17-2002 15:52 |
