12-24-2012, 06:23 | #1 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1857522 Status: Offline Thanks Meter: 0 | K608i Dead after unlock SETool RUNNING v 1.1203/01.14/UNI CARD SERIAL 00178134 PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 LDR:070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:35684200192163 CERT:RED ACTIVE CID:49 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 97 secs. |
12-24-2012, 19:50 | #3 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
