10-04-2010, 22:59 | #1 (permalink) |
No Life Poster Join Date: May 2009
Member: 1028392 Status: Offline Thanks Meter: 87 | K608i dead, please help. check logs. Code: RUNNING v 1.088/UNI CARD SERIAL USBFLASH DRIVER VERSION 02.02.00.05 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxx CERT:RED ACTIVE CID:49 COLOR:RED Model (from GDFS):K608i Brand:Telefonica MAPP CXC article: R2T002 prgCXC1250014_EU_1_MI MAPP CXC version: R2T002 Language Package: EUROPE_1 CDA article: CDA102378/19 CDA version: R6A Default article: cxc1250017 Default version: R2T002 PROVIDER: MULTIPLE Network LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 19 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2T002_CXC1250014_EU_1_MI" HDR block not accepted,error: 09 Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "52770021" SIGNING... Unlock DONE Elapsed: 58 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED ACTIVE CID:49 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 6 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 67 secs. flashing erom --------------------------------- RUNNING v 1.088/UNI CARD SERIAL xxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2T002_CXC1250014_EU_1_MI" HDR block not accepted,error: 09 SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\SETOOL\Setool V1.01\eroms\db2000\k600_k608_v600_EROM_RED49.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... SSW flashing failed [09] Elapsed: 106 secs. RUNNING v 1.088/UNI CARD SERIAL xxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2T002_CXC1250014_EU_1_MI" HDR block not accepted,error: 09 SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\SETOOL\Setool V1.01\eroms\db2000\k600_k608_v600_EROM_RED49.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... SSW flashing failed [09] Elapsed: 106 secs. after recovery mode: --------------------------- RUNNING v 1.088/UNI CARD SERIAL xxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2T002_CXC1250014_EU_1_MI" HDR block not accepted,error: 09 SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\SETOOL\Setool V1.01\eroms\db2000\k600_k608_v600_EROM_RED49.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... SSW flashing failed [09] Elapsed: 106 secs. identify: ------------ RUNNING v 1.088/UNI CARD SERIAL xxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 11 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 3 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 11 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... Elapsed: 9 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED ACTIVE CID:49 COLOR:RED can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 60 secs. CFG:000000000000 file "" can't be found or opened Elapsed: 0 secs. CFG:000000000000 SERVER CREDITS LEFT/USED: 18/12 CARD COUNTERS: FLASH 43, UNLOCK 25 Elapsed: 2 secs. CFG:000000000000 file "gdfs.bin" can't be found or opened Elapsed: 0 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 err: [45/C9] loader prologue returns invalid status ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 err: [45/C9] loader prologue returns invalid status ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 REC:050729 1301 NPA1CXC1325413_CERTLOADER R4C Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED can't open file "frec\zbrowncid49.bin" Recovery failed. Phone dead. Elapsed: 63 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 4 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... Elapsed: 9 secs. CFG:000000000000 llbug:COM7 open error: "Acceso denegado" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 0 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 11 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 13 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 4 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED llbug:COM7 open error: "Acceso denegado" Elapsed: 0 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 5 secs. CFG:000000000000 Will write GDFS now. ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 11 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... Elapsed: 17 secs. CFG:000000000000 llbug:COM7 open error: "Acceso denegado" Can't load ID loader ! Elapsed: 0 secs. CFG:000000000000 llbug:COM7 open error: "Acceso denegado" Can't load ID loader ! Elapsed: 0 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED ACTIVE CID:49 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 30 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 5 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... Elapsed: 9 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 9 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 3 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 11 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 13 secs. CFG:000000000000 llbug:COM7 open error: "Acceso denegado" FAILED TO SETUP PHONE Elapsed: 0 secs. CFG:000000000000 llbug:COM7 open error: "Acceso denegado" FAILED TO SETUP PHONE Elapsed: 0 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2AE001_CXC1250014_EU_1_MI" HDR block not accepted,error: 09 SWITCHING TO "USB"... INTERFACE NOT CHANGED writing "C:\_k608\k600_k608_v600_EROM_RED49.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... SSW flashing failed [09] Elapsed: 81 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 skipping empty loader... ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 err: [45/C9] loader prologue returns invalid status ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 err: [45/C9] loader prologue returns invalid status ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 REC:050729 1301 NPA1CXC1325413_CERTLOADER R4C Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED can't open file "frec\zbrowncid49.bin" Recovery failed. Phone dead. Elapsed: 47 secs. PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED ACTIVE CID:49 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 63 secs. unlock/repair PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Unlock FAILED Elapsed: 5 secs. if i want to flash i get: ------------------------------ ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxxxxx CERT:RED unsupported combination. Elapsed: 13 secs. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
