04-26-2010, 16:26 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | k610 error when empty fill... CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35463801744208 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\drive c\setool\SETOOL v1.01\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... WRITING OTP IMEI:35463801744208 write OTP fail,err:05 OTP WRITE FAILURE WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "10020677" SIGNING... Elapsed: 217 secs. |
05-11-2010, 18:28 | #3 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Caracas, Venezuela
Member: 663090 Status: Offline Thanks Meter: 25 | Same problem here trying to repair IMEI, what can we do? Code: SIGNED MODE (USING SERVER) CFG:100000000100 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220801238265 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "C:\Documents and Settings\Administrador\Escritorio\v1.01\gdfs_in_ssw_format\db2020\K790_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "C:\Documents and Settings\Administrador\Escritorio\v1.01\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... WRITING OTP IMEI:35220801239465 write OTP fail,err:05 OTP WRITE FAILURE WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "04665302" SIGNING... Elapsed: 51 secs. |
05-11-2010, 18:40 | #4 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | OTP: LOCKED:1 One time programmable 352208012382654 is a correct imei for k790a to change it 1 check your country laws 2 use the gdfs solution (unlock +imei change) |
05-12-2010, 08:24 | #5 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
* mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 K610 after successful RECOVERY * switch to empty board tab * select K610 * add K610_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 K610 * flash with red 52 firmware check on settings signed mode "customize phone after flash" * DONE. | |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-12-2010, 09:26 | #6 (permalink) | |
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
did you see the log in the 2nd post above yours | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
