Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 08-13-2009, 00:51   #1 (permalink)
Temporary banned !!
Member: 1000201
k610i unlock procedure how to do?
v0.915038/UNI
CARD SERIAL: 00020648
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:101000000000000
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901239221 CERT:RED
FLASH CID:49 COLOR:RED
Model (from GDFS):K610i
MAPP CXC article: R1CD001 prgCXC1250539_HUTCHISON_TH
MAPP CXC version: R1CD001
Language Package: HUTCH_1
CDA article: CDA102497/46
CDA version: R14A
Default article: cxc1250376
Default version: R1CD001
PROVIDER: MULTIPLE
Network LOCKED
SEARCH:G:\flash\k610\cid51\R1JC002_1250374_GENERIC _TH.ssw
can't open file G:\flash\k610\cid51\R1JC002_1250374_GENERIC_TH.ssw
SEARCH:C:\15\45a00000.a01.ssw
can't open file C:\15\45a00000.a01.ssw
SEARCH:G:\flash\k610\cid51\R1JC002_FS_RUSSIA_TH_RE D_CID51.ssw
can't open file G:\flash\k610\cid51\R1JC002_FS_RUSSIA_TH_RED_CID51 .ssw
RESTORATION FILE NOT PRESENT
"R1CD001_CXC1250539_HUTCHISON_TH"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
SECURITY UNITS BACKUP CREATED.
Elapsed: 114 secs.
CFG:101000000000000
FLASH CID: 0049
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
bypassing security...
server step1 error:No server found.
loader unlock failed, that is fatal
Elapsed: 20 secs.
CFG:000000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
phone CID not supported in that mode
Elapsed: 13 secs.
Old 08-13-2009, 01:39   #2 (permalink)
dzunlocker's Avatar
Member: 79640
Sonork: 1577251
1- Download file from link :http://rapidshare.com/files/26675562...ON_TH.rar.html and extract to setool\rest folder
2- Choose correct model and Convert phone to CID 52 or 53 using scripts from setool/script folder (use Com cable, Signed mode must be checked) and Fully power On phone after conversion use identify to check if phone converted.
3-Unlock & repair (signed mode + alternative sec bypass )
Regards
Old 08-13-2009, 20:54   #3 (permalink)
togelmania's Avatar
Member: 468970
Sonork: M.G.T
This log after sucsesfull unlock watch it :
PRELOADER SECURITY BYPASS ENABLED
CFG:10110110110100
BOOTROM MODE DETECTED
Speed:921600
Flash ID check:2019
Flash props sent ok
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35194201016910 CERT:N/A
Brand:Generic
MAPP CXC article: R1ED001 prgCXC1250374_GENERIC_TH
MAPP CXC version: R1ED001
Language Package: APAC
CDA article: CDA102514/2
CDA version: R2A
Default version: R1ED001
PROVIDER: MULTIPLE
Network LOCKED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
Elapsed: 10 secs.
CFG:10110110110100
Speed:921600
Flash ID check:2019
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM72
PHONE READY TO PROCEED
EXECUTOR STARTED
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
FINALLY PRESS "READY"
FLASH CID: 0049
Speed:921600
Starting embedded bootloader...
INT LDRB2020_PRELOADER_FOR_SETOOL2
LDRB2020 LOADER FOR SETOOL2
Flash ID check:2019
Flash props sent ok
FOUND VERSION "R1ED001_CXC1250374_GENERIC_TH"
Searching...
IMEI handler determined.
USERCODE RESET TO "0000"
Searching...
Firmware SIMLOCK check determined.
Unlock DONE
Elapsed: 139 secs.
CFG:10110110110100
FLASH CID: 0049
Speed:921600
Flash ID check:2019
Flash props sent ok
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35194201016910 CERT:RED
Brand:Generic
CDA version: R2A
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
Elapsed: 10 secs.
See red mark and you'll know your step Good luck bro...
Old 08-15-2009, 22:35   #4 (permalink)
Temporary banned !!
Member: 1000201
what does this mean
v0.915038/UNI
CFG:101000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 26 secs.
CFG:101000000000000
PROCEDURE WAS STOPPED BY USER
Can't load ID loader !
Elapsed: 68 secs.
CFG:101000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 22 secs.
Old 08-16-2009, 10:50   #5 (permalink)
togelmania's Avatar
Member: 468970
Sonork: M.G.T
In "setting" tab you must thick,,,
- sign mode
- enable alternative security bypass
- enable preloader security bypass
look this :
v0.915038/UNI
CFG:101000000000000
that mean you only thick
- sign mode
hope you luck..
Old 08-16-2009, 21:21   #6 (permalink)
Member: 600824
Originally Posted by gsmlocksez View Post
v0.915038/UNI
This is Root of your Problem.
Old 12-11-2009, 00:12   #7 (permalink)
Member: 1171864
yea tis is good man me sirvio mucho ede
Old 12-11-2009, 00:20   #8 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
v0.915038/UNI
CFG:101000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
CDA version: R14A
PROVIDER: MULTIPLE
Network LOCKED
SEARCH:G:\flash\k610\cid51\R1JC002_1250374_GENERIC_TH.ssw
SEARCH:G:\flash\k610\cid51\R1JC002_FS_RUSSIA_TH_RED_CID51.ssw
can't open file G:\flash\k610\cid51\R1JC002_FS_RUSSIA_TH_RED_CID51.ssw
Elapsed: 114 secs.
CFG:101000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 20 secs.
CFG:000000000000000
FLASH CID: 0049
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 13 secs.
LOL
ok many wrongs.
1. DONT POST CARD SERIAL NR.. MAKE IT ---XXX
2. ITS CID 49, your trying to flash it with CID 51 files
3. URE trying to use cid52/53 bypass method on cid 49
so upgrade to cid 52
then dl cid 52 flash files
put same main flash file in restore section
mark signed mode
alternative bypass security
cutomize after flash
unlock during flash
then press flash
br
Old 01-19-2010, 11:31   #9 (permalink)
Member: 342371
Thumbs up K610i unlock 100%
select these option to unlock k610i cid 49
8800 is not anything unlocks for how to do it? evaca26 BlackBerry (RIM) 0 12-12-2008 16:20
Unlock c160 how to do Unlocksupport Ultimate-Sam 1 11-04-2008 17:20
How to do EMPTY FILL PROCEDURE on k790i??? Unlocker_001 SETool2 0 06-18-2008 18:31
PROCEDURE HOW TO UNLOCK P910/P910i lemor Twisterflasher 36 08-11-2007 18:28
k610i phone code unlock how to do? gsmindia Cruiser Suite 7 12-01-2006 03:27
Page generated in 0.43942 seconds with 11 queries
