12-18-2009, 12:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | K750 blinking after succefull flash FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35437701017643 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:200D Flash props sent ok FOUND: R1DB001_CXC125952_EU_1_CL Restore from:R1DB001_CXC125952_EU_1_CL can't open file "C:\v0.914029\rest\R1DB001_CXC125952_EU_1_CL" writing D:\Firmware\Sony Ericsson\K750\CID49\K750_R1DB001_MAIN_EU_1_CL_RED4 9.mbn CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:291 Will flash 291 blocks... SSW loading returns:0 writing D:\Firmware\Sony Ericsson\K750\CID49\K750_R1DB001_FS_EMEA_1_RED49.f bn CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:161 Will flash 161 blocks... SSW loading returns:0 LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 492 secs. Whats problem ???????? ~ZubairArain~ |
12-19-2009, 10:26 | #6 (permalink) | ||
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
if this not work then 100% hardware | ||
12-19-2009, 22:14 | #9 (permalink) | |
download the restfile from support. put in rest folder. do again. | |
The Following User Says Thank You to GSMman187 For This Useful Post: |
12-20-2009, 16:08 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | no he needs to re hot flash chip In fact he is not having rest file yet he should b able to restore phone because if restoration file is not present phone should not even turn on |
k750 Dead After Wron Flash Please Help | hasssan | Cruiser Suite | 6 | 06-24-2006 19:32 |
k750 blinks after flash | btl | SonyEricsson (USB-Smart) | 6 | 12-06-2005 18:46 |
6230 blinking after ppm flash. | TRABEL | Nokia Hardware & Hardware Repair | 8 | 05-10-2005 01:58 |
V60 blinking after error flash ?? | med22 | Motorola P2k | 7 | 08-22-2003 12:20 |
