Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 11-01-2006, 08:45   #1 (permalink)
Member: 352247
K750 dead after flash
K750 brown color CID/49 by mistake I revert it to red color.now, phone dosent switch on.I flash it with setool3.but after click testpoint button.the process will stop when recive to "trying to embedded bootlaoder" stage. I test any way that you think.with SEtool3 box.(like as write GDFS, put erom ...)but every time I tryed.the process stoped as I describe above.I have three k750 phones that have this problem.
Old 11-01-2006, 08:54   #2 (permalink)
Kashif Khan's Avatar
Member: 88016
No problem,your problem can be solve if you will upload your setool log.
Old 11-01-2006, 09:01   #3 (permalink)
Member: 352247
Thanks for your help,but how can i upload my setool log.
Old 12-13-2006, 06:44   #4 (permalink)
Member: 331495
Its not problem that you reverted the color from brown to red. Try on lower baud rate, check complete phone. If not working try many times.
If not working then, you can flash erom and gdfs.
I had similar problems with k750 and other se phones, and at the end I solved it.
Use the latest prog, and put rest files in rest directory. You have them on support site.
Old 01-24-2007, 10:35   #5 (permalink)
Member: 185686
hey i have just simple advise for u if u dont use setools before i think u should't be try with se tools mostly peoples killed the phone with setools its not meanings by setools is not good but if u dont know about it so dont try u just try with hwk latest vir just wite mcu and cust files and then gdfs file i hope ur phone will be ok its very eassy and simple thanks
Old 02-20-2007, 07:28   #6 (permalink)
Member: 373786
Sonork: 100.1601935
I try everything but phone still dead
GUI v0.91380068/UNI
Card serial:00010090
Loaded 51 flash descriptors
ATTACH TESTPOINT NOW, THEN PRESS TESTPOINT OK
Open COM port OK
ChipID:8040,EMP protocol:0301
PHONE IS INVISIBLE (00000000)
NO valid FLASH CID detected (00)
Speed:921600
RELEASE TESTPOINT NOW, THEN PRESS TESTPOINT OK
loader payload not accepted
failed to load CERTLOADERS,try to use RECOVERY.
Elapsed:24 secs.
Open COM port OK
FLASH CID detected:0
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:3525580184xxxx CERT:RED
Loader:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB
Flash ID check:890D
Flash props sent ok
writing D:\Box\Setool3\v0[1].91380068\eroms\k750_w800_z520_new_erom.cry
CURRENT FLASH FILE CID:254
SSW uses dynamic hash, dynamic hash len is:2
Will flash 2 blocks...
SSW loading returns:0
writing D:\Box\Setool3\v0[1].91380068\gdfs_in_ssw_format\k750_w800_gdfs_in_ssw _format.ssw
SSW uses dynamic hash, dynamic hash len is:16
Will flash 16 blocks...
writing D:\Documents and Settings\Mobile\Desktop\k750\k750_R1CA021_EU_EMEA_ AMERICA2_FR1_MAIN.cry
SSW uses dynamic hash, dynamic hash len is:288
Will flash 288 blocks...
writing D:\Documents and Settings\Mobile\Desktop\k750\k750_R1CA021_EMEA_2_F S.cry
SSW uses dynamic hash, dynamic hash len is:161
Will flash 161 blocks...
Setting up GDFS...
IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!!
ORIGINAL IMEI:3525580184xxxx
CURRENT IMEI:3565510010xxxx
Clearing total time...
Writing simlocks...
ALL UNLOCK/LOCK CODES SET TO "74080205"
Signing...
control keys complete.
full sig complete.
CSloader version:
COMPACT_SEMC_FS_LOADER_SETOOL2_V23
loader startup: executed
loader filesystem startup: executed
loader GDFS startup: executed
loader unlock: executed
writing tpa/preset/custom/C3_PCA_G3v2.cer
writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
writing tpa/preset/custom/customize.xml
writing tpa/preset/custom/DESKTOP_HOOK_2.itm
writing tpa/preset/custom/Entrust.net Root Certificate.cer
writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
writing tpa/preset/custom/GAMES_HOOK_3.itm
writing tpa/preset/custom/GTE_CyberTrust_Root.cer
writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
writing tpa/preset/custom/Root.cer
writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
writing tpa/preset/custom/ThawtePremium.der
writing tpa/preset/custom/ThawteServerCA.cer
writing tpa/preset/custom/Utiroot.cer
writing tpa/preset/custom/VeriSignClass3Root.cer
writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed:566 secs.
Old 04-21-2007, 08:45   #7 (permalink)
Member: 470860
I face this problem b4 too.. The key word "IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!!"
So i try to flash it without select/tick any file 1st..
After the dummy flash done.. i flash it again with flash file selected.. It work and the phone was switch on successfully..
k750 dead after flashing with universal box zijean Sony Ericsson Hardware Repair Area 5 05-18-2009 19:22
K750 Dead After Flash gsmawake Universalbox 3 01-27-2007 11:00
K750 Deade after flash with criser ..::AppleLinks::.. Cruiser Suite 4 09-15-2006 17:09
Repair K750 dead after flashing R1CA021 mpshop Cruiser Suite 1 08-25-2006 14:15
K750 dead after flashing R1CA021. Lead Cruiser Suite 0 05-30-2006 14:14
Page generated in 1.95008 seconds with 11 queries
