12-03-2006, 19:18 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 394425 Status: Offline Thanks Meter: 0 | k750 dead. Won't turn on after W800 flash! Can anybody suggest a step by step way of recovering this phone, and the suggested software to do it. I have cruiser cable. Also, I keep getting ERROR 300312 with semc_tool 3.3 and the following when trying to repair with seTool2 GUI v0.91373/UNI standalone version engaged. Card serial:00001283 Loaded 49 flash descriptors RECOVERY MODE STARTED Open COM port OK Recovery:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Fetching phone data from OTP OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxx CERT:BROWN bad file, will not flash it. Recovery failed. Phone dead. Elapsed:1 secs. Thanks... |
12-04-2006, 00:59 | #3 (permalink) |
Member: 394425 Status: Offline Thanks Meter: 0 | managed to flash the following w800 files: W800_R1BC002_MAIN_EU_EMEA.mbn W800_R1BC002_FS_EU1.fbn but got error when trying to complete phone. GUI v0.91373/UNI standalone version engaged. Card serial:00001283 Loaded 49 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:36 Speed:115200 OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxxxxxxxxCERT:RED Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:36 Speed:115200 OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxxxxCERT:BROWN Loader:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok Flashing MAIN firmware: W800_R1BC002_MAIN_EU_EMEA.mbn CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is:291 Will flash 291 blocks... SSW loading returns:0 Flashing FS image: W800_R1BC002_FS_EU1.fbn CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is:149 Will flash 149 blocks... SSW loading returns:0 Don't forget check complete ! Open COM port OK OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxxxxCERT:RED CSloader version: 051101 1900 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3J loader startup: executed csloader refused to start fs services,error is:1 loader filesystem startup failed, that is fatal Elapsed:2641 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:36 Speed:115200 loader payload not accepted failed to load CERTLOADERS,try to use RECOVERY. Elapsed:4 secs. Open COM port OK Elapsed:2 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:36 Speed:921600 OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxxxxCERT:RED Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:36 Speed:921600 OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxCERT:BROWN Loader:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok Flashing FS image: W800_R1BC002_FS_EU1.fbn CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is:149 Will flash 149 blocks... SSW loading returns:0 Don't forget check complete ! Open COM port OK OTP status:0 locked:1 CID:36 PAF:1 IMEI:xxxxxxxxxxxxxCERT:RED CSloader version: 051101 1900 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3J loader startup: executed csloader refused to start fs services,error is:1 loader filesystem startup failed, that is fatal Elapsed:189 secs. |
06-28-2007, 15:36 | #4 (permalink) |
Insane Poster Join Date: Mar 2005 Location: hungary
Member: 125169 Status: Offline Thanks Meter: 3 | Try to reflash with right flash files. The .mbn files are semctool flashes. The flash files must be in .st2 format for setool2 If you need some help PM for me. |
06-29-2007, 11:06 | #5 (permalink) | |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Quote:
USE NEW FRIMWARE ALSO WRITE GDFS IN FORMAT.SWW AND FLASH UR PHONE ALL WELL BE OKEY OR TELL ME THAT HOW U FLASH UR PHONE REGARDS GSM MIND | |
HTC Touch Diamond Wont turn on after bad flash | soundb0y | HTC & PDA WM( With Touchscreen) | 7 | 02-07-2010 06:17 |
E90 won't turn on after flash!!!!!! | sunshinelin | Cyclonebox | 4 | 07-07-2009 00:56 |
K750 wont turn on after flash | kp84 | SonyEricsson (USB-Smart) | 3 | 07-03-2006 16:17 |
k750 does not turn on after unlock | Blitzkrieg_Hop | Cruiser Suite | 9 | 05-22-2006 15:18 |
8210 won't turn on and won't flashing at all | hooi76 | Nokia Hardware & Hardware Repair | 4 | 06-28-2004 14:00 |
