11-11-2010, 13:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | K750 how to repair this SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 890D GOT SEED:4D5676E82180496815C03B79 P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701496572 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 37 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701496572 CERT:BROWN FLASH ID: 890D writing "D:\Software\SETool\SETOOLS_v1.01\gdfs_in_ssw_form at\db2010\k750_w800_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 16 Will flash 16 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "10828516" SIGNING... Elapsed: 30 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701496572 CERT:BROWN FLASH ID: 890D writing "D:\Software\SETool\SETOOLS_v1.01\eroms\db2010\k75 0_w800_z520_new_erom.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "18451506" SIGNING... Elapsed: 13 secs. CFG:000100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701496572 CERT:BROWN FLASH ID: 890D writing "D:\Firmware\SETool\K750\K750_R1CA021_MAIN_EU_1_CL _RED49.mbn" CURRENT FLASH FILE CID:49 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 288 Will flash 288 blocks... writing "D:\Firmware\SETool\K750\K750_R1CA021_FS_EMEA_2_RE D49.fbn" CURRENT FLASH FILE CID:49 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 161 Will flash 161 blocks... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 553 secs. |
11-11-2010, 13:36 | #2 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | After flashing with these files turn on lights but not powerd on. CFG:000100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701496572 CERT:BROWN FLASH ID: 890D writing "D:\Firmware\SETool\K750\k750r1l\k750r1l_main_euro .cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 282 Will flash 282 blocks... writing "D:\Firmware\SETool\K750\k750r1l\k750r1l_fs.emea6. cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 157 Will flash 157 blocks... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 619 secs. |
11-11-2010, 18:49 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Quote:
11-11-2010, 19:47 | #4 (permalink) |
Freak Poster Join Date: Jan 2010 Location: cyprus
Member: 1223870 Status: Offline Sonork: .............. Thanks Meter: 74 | PHONE SUCCESSFULLY RESET TO DEVELOPER STATE .. you done a recovery from empty fill tab,after you wrote gdfs in ssw format,normaly after you must full flash the phone in sony ericsson tab using signed mode and customise phone after flash ,check preloade bypass if i remember exactly i do not have the box with me naw.the good thing is your phone is 99% not hardware,is software,try again recovery-bring phone to developer state,stai there on empty fill tab and write gdfs on ssw format ,write erom ,you find them on setool folder,after ,go to sony ericsson tab and check signed server,enable... ,customise phone after flash and do full flash .be sure to flash the phone with the proper flash files. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
