Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 03-03-2010, 12:21   #1 (permalink)
rockindheeraj's Avatar
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
K750i flashing error
HI FRIENDS K750 TRY TO FLASH BUT SUDDENLY GOT ERROR AT FLASHING MAIN FILE AT 24 BLOCKS THEN IF ITRY TO FLASH SHOWS
SIGNED MODE (USING SERVER)
CFG:100110000000
ChipID:8040,EMP protocol:0301
OBSOLETE EROM,FORCING "RETAIL" PHONE STATE
OBSOLETE EROM,FORCING "CID49"
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:921600
OTP: LOCKED:1 CID:36 PAF:1 IMEI:35682800301357 CERT:RED
ldr_on_ldr hdr no ack (11)
Elapsed: 10 secs.
PLZ HELP
Old 03-03-2010, 12:31   #2 (permalink)
laxman kumar's Avatar
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
hi friend
open setool exe and add the flash file main and fs file and go to settings and mark the customize phone after flash. and press flash . and use usb cable
The Following User Says Thank You to laxman kumar For This Useful Post:
Old 03-03-2010, 12:36   #3 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
Originally Posted by laxman kumar View Post
hi friend
CFG:100100000000
FLASH CID: 0049
Speed:921600
Elapsed: 13 secs.
TRIED BY THE METHOD WHICH U SAID BUT SAME
Old 03-03-2010, 12:54   #4 (permalink)
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
but y you useing server unmark the server then tre it
Old 03-03-2010, 13:02   #5 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
Its cid 49 color bRown it requires signed server mode
Old 03-03-2010, 13:05   #6 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
CFG:100110000000
FLASH CID: 0049
Speed:921600
Elapsed: 10 secs.
PLZ HELP
use ufs as interface problem will done.
Old 03-03-2010, 13:07   #7 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
Used ufs as inter face flashing main file stops at block 24
Old 03-03-2010, 13:08   #8 (permalink)
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
bro check your log file
this phone is red
Old 03-03-2010, 13:14   #9 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
SORRY FRIEND I DINT SEE THE LOGS PROPERLY HERE THE LOG
CFG:100110000000
FLASH CID: 0049
Speed:921600
FLASH ID:890D
FLASH CID:36 COLOR:BROWN
Model (from GDFS):K750i
Brand:Generic
MAPP CXC article: R1DB001 prgCXC125952_EU_1_CL
MAPP CXC version: R1DB001
Language Package: EMEA_5
CDA article: CDA102337/1
CDA version: R2A
Default article: cxc125953
Default version: R1DB001
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
Elapsed: 6 secs.
Old 03-03-2010, 13:16   #10 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
Plz help friend ....... I dont know what to do
Old 03-03-2010, 13:35   #11 (permalink)
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
frist you go to tab Empty fill & repair add k750_w800_gdfs_in_ssw_format.ssw ( and ) add k750_w800_z520_new_erom.ssw and flash.
after this flash your phone as normal with cid-49 new firmware .
Old 03-03-2010, 14:10   #12 (permalink)
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
Can u give me ur yahoo id MR LAKSHMAN
Old 03-03-2010, 15:11   #13 (permalink)
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
[email protected]
Old 03-03-2010, 15:57   #14 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
It's Hardware problem dear
Old 03-03-2010, 23:01   #15 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
CFG:100110000000
FLASH CID: 0049
Speed:921600
Elapsed: 10 secs.
PLZ HELP
that is hardware problem and nothing to do with software. usually it is bad soldered flash chip.
latest mid-range semc phones quality is below zero.
as last resort, you can try to raise voltage on FLASH VPP upto 12v
(for start, try to flash it with dcu60, it also has increased voltage)
but what say to customer if phone works before servicing?
have no idea - think yourself- that is risk that you including in each service cost.
sadly, but such thing can be happened - flash sector can read good, but fails on erase/write.
K750i Flashing Error Urgent surajmobile Universalbox 7 07-17-2008 10:43
K750i flash error icedragon69 SETool2 3 03-09-2007 08:01
k750i flashing error 3 & always 8% brusko HWK 2 07-22-2006 23:32
K750i - FLASH errors mobilextreme Cruiser Suite 0 05-13-2006 12:31
K750i flashing error Bakl SonyEricsson (USB-Smart) 2 11-30-2005 17:25
Page generated in 0.23990 seconds with 9 queries
