10-25-2010, 15:20 | #1 (permalink) |
Registered User Join Date: Apr 2010 Location: madurai thirumangalam
Member: 1286002 Status: Offline Sonork: who are you Thanks Meter: 22 | k750i flashing error pls help all setool master SIGNED MODE (USING SERVER) CFG:100110100000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35340601395121 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID:890D writing "C:\Documents and Settings\Administrator\Desktop\k750\k750_R1BC002_c hina_main.ssw\k750_R1BC002_china_main.ssw.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 313 HDR block not accepted,error: A9 Elapsed: 21 secs. |
11-18-2010, 13:22 | #3 (permalink) | |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote: I have one piece with power on poroblem after unlock , flash and write gdfs take a look RUNNING v 1.09/UNI USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 31 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 FLASH ID: 890D OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED ACTIVE CID:49 COLOR:RED Model (from GDFS):K750i Brand:PTC ERA MAPP CXC article: R1CA021 prgCXC125952_EU_1_CL MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102338/100 CDA version: R4A Default article: cxc125953 Default version: R1CA021 PROVIDER: 260-02 Network LOCKED USERCODE:0000 RESTORATION FILE NOT PRESENT "R1CA021_CXC125952_EU_1_CL" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will backup GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID: 890D LDR:070417 1739 NPACXC1327364_COMPACT_SEMC_CS_LOADER__P3T loader GDFS startup executed stated number of vars:1256 Found:850 units Found:406 units gdfs read done,gdfs_35XXXXXXXX.bin written Phone detached Elapsed: 90 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID: 890D LDR:070417 1739 NPACXC1327364_COMPACT_SEMC_CS_LOADER__P3T Executing CSCA-based unlock. PLEASE SELECT "USB" AS INTERFACE Unlock FAILED Elapsed: 19 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D FOUND VERSION "R1CA021_CXC125952_EU_1_CL" can't open file "C:\setool2g\rest\R1CA021_CXC125952_EU_1_CL" Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "03456632" SIGNING... Unlock DONE Elapsed: 95 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID: 890D writing "C:\setool2g\flash\k750\R1CA021_GENERIC_FR1_FS.cry " CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 149 HDR block not accepted,error: A9 Elapsed: 34 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID: 890D writing "C:\setool2g\flash\k750\R1DB001_ORANGE_GEN_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 153 HDR block not accepted,error: A9 Elapsed: 20 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" err: bad answer [00] Elapsed: 38 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B FLASH ID: 890D writing "C:\setool2g\flash\k750\R1DB001_ORANGE_GEN_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 153 HDR block not accepted,error: A9 Elapsed: 27 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D FOUND VERSION "R1CA021_CXC125952_EU_1_CL" can't open file "C:\setool2g\rest\R1CA021_CXC125952_EU_1_CL" writing "C:\setool2g\flash\k750\R1DB001_ORANGE_GEN_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 153 Will flash 153 blocks... writing "C:\setool2g\flash\k750\R1DB001_EMEA_1_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 161 Will flash 161 blocks... writing "C:\setool2g\flash\k750\k750custpack.rar" bad file, will not flash it. Elapsed: 624 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D FOUND VERSION "R1CA021_CXC125952_EU_1_CL" can't open file "C:\setool2g\rest\R1CA021_CXC125952_EU_1_CL" Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "43065182" SIGNING... Unlock DONE Elapsed: 56 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D FOUND VERSION "R1CA021_CXC125952_EU_1_CL" can't open file "C:\setool2g\rest\R1CA021_CXC125952_EU_1_CL" writing "C:\setool2g\flash\k750\R1DB001_ORANGE_GEN_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 153 Will flash 153 blocks... writing "C:\setool2g\flash\k750\R1DB001_EMEA_1_fs.ssw. cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 161 Will flash 161 blocks... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 can't get packet start. GDFS startup failed,error is 00 [00] loader GDFS startup failed, that is fatal Elapsed: 890 secs. CFG:001000000000 file "" can't be found or opened Elapsed: 0 secs. CFG:001000000000 file "" can't be found or opened Elapsed: 0 secs. POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK DONE EXTRACTING. CFG:001000000000 Will write GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D UPLOADING REST FILE "C:\setool2g\gdfs_35XXXXXXXX.bin"... bad file, will not flash it. Setting up GDFS... will write 1256 units done Phone detached Elapsed: 85 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D UPLOADING REST FILE "C:\setool2g\gdfs_35XXXXXXXX.bin"... bad file, will not flash it. Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "06063840" SIGNING... Unlock DONE Elapsed: 40 secs. CFG:001000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:460800 OTP LOCKED:1 CID:49 PAF:1 IMEI:35XXXXXXXX CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB FLASH ID: 890D FOUND VERSION "R1CA021_CXC125952_EU_1_CL" can't open file "C:\setool2g\rest\R1CA021_CXC125952_EU_1_CL" writing "C:\setool2g\flash\k750\cid 49\R1DB001_125952_EU_1_CL.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 291 Will flash 291 blocks... writing "C:\setool2g\flash\k750\cid 49\R1DB001_EMEA_1_fs.ssw.cry" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 161 Will flash 161 blocks... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 913 secs. still , phone dont power on any solution to repair ? | |
12-09-2011, 12:13 | #4 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | Quote:
Change file 10000% Success Tested Me ....... Select This File - K750_R1AA008_MAIN_EU_1_CL_RED49.mbn K750_R1AA008_FS_EUROPE_1_RED49.fbn | |
