12-03-2008, 08:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks Meter: 51 | K750i...HDR block not accepted,error:A9 v0.914037/UNI CARD SERIAL: 0000000 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:890D Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35340601513202 CERT:RED FLASH CID:49 COLOR:RED Model:K750i MAPP CXC article: R1CA021 prgCXC125952_EU_1_CL MAPP CXC version: R1CA021 Language Package:EMEA_6 CDA article: CDA102337/103 CDA version: R3A Default article: cxc125953 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35340601513202 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:890D Flash props sent ok FOUND: R1CA021_CXC125952_EU_1_CL Restore from:R1CA021_CXC125952_EU_1_CL HDR block not accepted,error:A9 Searching... Firmware OTP check determined. Setting up GDFS... Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "20123125" Signing... control keys complete. full sig complete. Unlock DONE Elapsed: 73 secs. Open COM port OK ChipID:8040,EMP protocol:0301 |
12-03-2008, 09:10 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Bosnia, Kiseljak Age: 41
Member: 85694 Status: Offline Thanks Meter: 48 | - Did you select "Signed mode" in settings? If yes, deselect it. - Try with speed 115200 - If still get this message, then make desired operation (unlock, imei change etc) and after that, flash only main part without complete phone... |
The Following 2 Users Say Thank You to Luc+Luc For This Useful Post: |
03-04-2009, 15:42 | #4 (permalink) |
Junior Member Join Date: Oct 2005 Location: RUSSIA Age: 51
Member: 194746 Status: Offline Thanks Meter: 1 | It is log: PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:3546230******* CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R4EA031_CXC1250316_GENERIC_HN" writing "C:\SE_TOOL\w810\R4EA031_1250316_GENERIC_HN.ssw\R4 EA031_1250316_GENERIC_HN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:344 Will flash 344 blocks... SSW loading returns:0 writing "C:\SE_TOOL\w810\R4EA031_1250316_GENERIC_HN.ssw\R4 ED001_BALTIC_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:157 Will flash 157 blocks... SSW loading returns:0 writing "C:\SE_TOOL\GDFS\GDFS\w810_gdfs\w810_gdfs_in_ssw_f ormat.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:32 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35462301743591 CURRENT IMEI:35906100020285 WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "26554133" SIGNING... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 2964 secs. Before that here I had "HDR block not accepted, error: A9", but used these options (we look attach) Phone has revived |
03-04-2009, 16:20 | #5 (permalink) |
Member: 194746 Status: Offline Thanks Meter: 1 | P.S. I can not add files. I am us: R4EA031_1250316_GENERIC_HN.ssw.cry R4ED001_BALTIC_fs.ssw.cry w810_gdfs_in_ssw_format.ssw Without others files Such options: V - complete phone after flash V - unlock during flash procedure V - allow to chenge imei when unlocking V - format gdfs when wrining Flash and all work is correct Last edited by zaqwert; 03-04-2009 at 16:29. |
The Following User Says Thank You to zaqwert For This Useful Post: |
12-09-2011, 12:08 | #8 (permalink) |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | change file 10000% Success Tested Me ....... Select This File - K750_R1AA008_MAIN_EU_1_CL_RED49.mbn K750_R1AA008_FS_EUROPE_1_RED49.fbn |
HDR block not accepted,error: 19 | mobilezclinic | SETool2 | 6 | 07-28-2012 09:19 |
HDR block not accepted,error: 14 | Moiz Khan | Sony Ericsson | 16 | 07-15-2010 11:15 |
w580i HDR block not accepted,error: 19 | sandhu36 | Sony Ericsson | 7 | 06-30-2010 13:39 |
help W850 after DGFS Repair HDR block not accepted,error: 19 | sniper007 | SETool2 | 2 | 03-11-2009 18:56 |
urgent seetool hdr block not accepted,error a9 | shamshad quresh | SETool2 | 7 | 12-23-2008 15:23 |
