01-18-2009, 19:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Bangladesh
Member: 549796 Status: Offline Thanks Meter: 56 | K750i unlock failed ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570501431829 CERT:RED FLASH CID:49 COLOR:RED Model:K750c MAPP CXC article: R1CA021 prgCXC125954_CHINA_CL MAPP CXC version: R1CA021 Language Package:CHINESE CDA article: CDA102295/7 CDA version: R2A Default article: cxc125953 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 12 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570501431829 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok writing "E:\SE TOOL-3\Flash File\k750\R1CA021\k750_R1CA021_EU_EMEA_AMERICA2_FR 1_MAIN.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:288 HDR block not accepted,error: A9 Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570501431829 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok LDR:070417 1739 NPACXC1327364_COMPACT_SEMC_CS_LOADER__P3T Executing CSCA-based unlock. Backup security data... loader startup: executed loader GDFS startup: executed loader unlock: executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM24 PHONE READY TO PROCEED. server step1 error:No server found. CSCA UNLOCK FAILED Elapsed: 79 secs. |
01-18-2009, 19:34 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,473 | dont tick mark use server and alternative security bypaas. no one option should be tick marked for this model just press unlock and repair botton and follow the software guides |
01-19-2009, 03:48 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | it is cid 49 no need server use ufs interface using se tool used power supply from cable or fully charge battery 1.identify 2. unlock |
The Following User Says Thank You to venuno For This Useful Post: |
01-19-2009, 03:53 | #5 (permalink) |
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | if dead phone flash main fs settings 1. unlock after flash 2. complete phone after flash |
10-16-2011, 17:48 | #7 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | am having problem with k750 after flash no power here is the log PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 LDR:061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLASH ID: 200D OTP LOCKED:1 CID:49 PAF:1 IMEI:35255801043600 CERT:RED ACTIVE CID:49 COLOR:RED SCRC READ FAILURE i try to write gdfs,unlock but i get unlock fail any solution |
unlock failed sfr 112??? | gurbuz | FuriousGold | 2 | 03-30-2010 10:22 |
K750i booting failed | manibul | Sony Ericsson Hardware Repair | 5 | 09-10-2008 21:04 |
K750i Booting fails - no color and certificate inside the phone?! | Mickey09 | Cruiser Suite | 24 | 08-24-2006 09:14 |
K750i Payloader Failed | smart_srini81 | HWK | 3 | 09-30-2005 20:14 |
Unlock K750i Brown fail !!! | tenferrari | TOTAL MultiServer | 2 | 08-09-2005 00:59 |
