01-15-2010, 00:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 821762 Status: Offline Thanks Meter: 17 | K770 cid 53 how unlock setool3 can't get packet start. CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35617902637016 CERT:RED FLASH CID:53 COLOR:RED Model (from GDFS):K770i Brand:Generic MAPP CXC article: R8BC004 prg1201-7587_GENERIC_VI MAPP CXC version: R8BC004 Language Package: CENT_EUROPE CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BC004 PROVIDER: 234-15 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 23 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110110000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35617902637016 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM18 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Starting embedded bootloader... can't get packet start. embedded flashloader not responds ! Elapsed: 262 secs. ????????????????????????????????????????? |
01-15-2010, 00:43 | #2 (permalink) |
Member: 821762 Status: Offline Thanks Meter: 17 | Job Done :) SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111111000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35617902637016 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM18 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Starting embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID:2019 FOUND VERSION "R8BC004_1201-7587_GENERIC_VI" writing "D:\GSM\Sony Ericson\Setool FLASH FILES\k770\cid 53\R8BC004_1201-7587_GENERIC_VI.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\GSM\Sony Ericson\Setool FLASH FILES\k770\cid 53\r8bc004_fs_cent_europe_vi_red_cid53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2980 Will flash 149 blocks... USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Processing script "D:\GSM\Sony Ericson\Setool FLASH FILES\k770\cid 53\R8BC004_1201-7587_GENERIC_VI.ssw"... Phone detached Elapsed: 592 secs. |
04-21-2010, 11:16 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | RESET the PHONE Bro.. Used v1.01 its FREE.. Code: PROCEDURE open v1.01 Step 1 -Go to SETTINGS Tab -Tick SIGNED MODE -Go back to SE PHONES/Select PHONE TYPE -Click RECOVERY TAB -PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Step 2 -Go to EMPTY FILL AND REPAIR Tab -Select Phone Model -Click Add / Go to SE Folder / gdfs_in_ssw_format / db2020 -Select K770_GDFS_SSW.ssw -Click FLASH tab -GDFS REPAIRING Step 3 -Go to EMPTY FILL AND REPAIR Tab -Select Phone Model -Click Add / Go to SE Folder / eroms / db2020 -Select DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw -Click Flash Tab -EROMS REPAIRED Step 4 flash main & fs -SETTINGS TAB -SIGNMODE@COMPLETE Br,. Rhyan777 |
The Following 5 Users Say Thank You to Rhyan777 For This Useful Post: |
04-24-2010, 12:54 | #6 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Poland Age: 44
Member: 18406 Status: Offline Thanks Meter: 84 | Quote:
for unlock step 2 and 4 is obsolete | |
08-25-2010, 13:44 | #7 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1066806 Status: Offline Sonork: 10203 Thanks Meter: 18 | Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:100000000000100 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35223902000000 ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal Elapsed: 221 secs. setool please any one help me thanks in advance [email protected] |
how to repair gdfs k770 cid 53 with log setool | kirta | SETool2 | 11 | 10-04-2017 11:51 |
w200 can't get packet start??? | shahzadthe1 | SETool2 | 7 | 11-12-2010 02:39 |
w700c can't get packet start. | zzqqkk112 | SETool2 | 0 | 03-11-2010 08:55 |
can't get packet start. packet not acknowledged (17) | Moiz Khan | Sony Ericsson | 0 | 01-18-2010 09:09 |
How 2 unlock k770 cid 53 | zablon | SETool2 | 0 | 04-11-2009 12:52 |
