10-19-2008, 07:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 406299 Status: Offline Sonork: none Thanks Meter: 280 | k770 cid53 corrupt gdfs moyobe chips repair via tp CARD SERIAL: kn celfone Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35238402350867 CERT:N/A FLASH CID:53 COLOR:RED LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDRB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 151 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35238402350867 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing F:\SETOOL\v0.914041\gdfs_in_ssw_format\db2020\K770 _GDFS_SSW.ssw CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED. Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "88180250" Signing... control keys complete. full sig complete. Elapsed: 43 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35238402350867 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing F:\SETOOL\v0.914041\eroms\db2020\DB2020EROM_CNV_RE D53_BROWN_CID49_DB2020.ssw CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED. Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "07716406" Signing... control keys complete. full sig complete. Elapsed: 12 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35238402350867 CERT:N/A FLASH CID:53 COLOR:RED phone CID not supported in that mode Elapsed: 2 secs. SIGNED MODE (USING SERVER). Open COM port OK phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 3 secs. SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35238402350867 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing F:\SETOOL\FLASHFILES SE TOOLS\ERICSON\K770\cid53\r8be001\R8BE001_1201-7587_GENERIC_VI.ssw CURRENT FLASH FILE CID:53 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing F:\SETOOL\FLASHFILES SE TOOLS\ERICSON\K770\cid53\r8be001\r8be001_fs_europe _4_vi_red_cid53.ssw CURRENT FLASH FILE CID:53 SSW uses complete hash, hash len is:2980 Will flash 149 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 381 secs. |
The Following User Says Thank You to JMJ ALBERT For This Useful Post: |
some doubts about gdfs and erom selection in repair via tp | zonetrichur | Sony Ericsson | 2 | 06-03-2009 06:08 |
gdfs repair via TP | google_uk | SETool2 | 7 | 03-26-2009 00:54 |
P990i GDFS repair via TP? | richello baring | SETool2 | 2 | 09-22-2008 03:27 |
W200 DB 2012 Repaire Via TP sucsesfull | rebi_cell | SETool2 | 4 | 08-16-2008 10:51 |
k800 corrupted gdfs can Ub repair it? | kungpaoski | Universalbox | 11 | 03-14-2008 21:33 |
