Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 01-28-2009, 18:08   #1 (permalink)
.:Gsm-Nikki:.'s Avatar
Member: 783315
Sonork: 100.1588917
Thanks Meter: 228
k770 CID53 dead after direct unlock
needed help
i got a k770 which i unlocked directly ( not patch )
it said unlock done
now its dead
its urgent
pls help
Old 01-28-2009, 18:28   #2 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,819
plz post logs for best guide
Old 01-28-2009, 18:49   #3 (permalink)
reaz.com's Avatar
Member: 310155
Thanks Meter: 1,304
may be rest file was missing...............
anyway post log here.......................
Old 02-20-2009, 05:59   #4 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 41
I have the same problem, here is the identify:
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED.
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0053
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35617902396703 CERT:RED
FLASH CID:53 COLOR:RED
PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
Flash ID check:897E
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed (1D)
loader GDFS startup failed, that is fatal
Elapsed: 25 secs.
Old 02-20-2009, 06:06   #5 (permalink)
Member: 974783
Thanks Meter: 64
rest file and bypass pack should be present before you do unlock
Old 02-20-2009, 06:08   #6 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,646
Identify 1st before any operation. to check id Bypass Package & Rest File are available & to backup security values.
Old 02-20-2009, 06:18   #7 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,153
phone must full flashed. only flashed normally-
then unlocked
Old 02-20-2009, 06:32   #8 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
try to full flash a mobile
stan1comm
Old 02-20-2009, 08:00   #9 (permalink)
Member: 410217
Thanks Meter: 44
Try to full flash with org. vr.
And patch unlocking
Old 02-21-2009, 16:17   #10 (permalink)
Member: 741453
Thanks Meter: 41
sucess!!! I full flash my k770 cid 53, whit main, fs and rest, and the phone is alive again!!! thanks
Z200 Dead After Direct Unlock With Cruiser gsmsharing Cruiser Suite 12 10-27-2007 07:02
z500a dead after direct unlock!! help gorgans Cruiser Suite 3 05-05-2006 01:28
Sagem MY-V55 dead after direct unlock with sws-sag 1.5 jean' ARM9 BASED M62 / M62+ 41 08-18-2005 14:02
U8330 dead after direct unlock flash .:Kuku:. FuriouS II 7 08-07-2005 19:22
help z500a dead after direct unlock gorgans Cruiser Suite 2 05-27-2005 20:15
Page generated in 0.36216 seconds with 8 queries
