k770 no ack during gdfs_readvar ! SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:9900,EMP protocol:0301 Speed:230400 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003367421 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 3 secs. |
Repair gdfs..... CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003367421 CERT:N/A FLASH CID:49 COLOR:BROWN Loader not responding ! Elapsed: 15 secs. |
reset phone.... u can try it pls. * select k770 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 k770 after successful RECOVERY * switch to empty board tab * select k770 * add k770_gdfs_ssw.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 k770 * flash with red 52 firmware * DONE. |
* select k770 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 k770 after successful RECOVERY * switch to empty board tab * select k770 * add k770_gdfs_ssw.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003367421 CERT:N/A FLASH CID:49 COLOR:BROWN Loader not responding ! Elapsed: 15 secs. Help me......... |
after follow the steps u show and i got this log when i press info: CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35223902752161 CERT:N/A FLASH CID:52 COLOR:RED can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 39 secs. still the same !! any1 please ? |
do this 1.go to setting tab 2.tick sing,alltanative,preloader 3.press unlock after that u can see gdfs start up fail at end 4.tick sing,preloader and unlock done post result |
i did this all but now "insert correct card" RUNNING v 1.01/UNI CARD SERIAL 00149506 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003792905 CERT:N/A FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35852401899806 Model (from GDFS):K770i Brand:Generic MAPP CXC article: R8BC004 prg1201-7587_GENERIC_VI MAPP CXC version: R8BC004 Language Package: RUSSIA CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BC004 PROVIDER: 234-15 Network LOCKED RESTORATION FILE NOT PRESENT "R8BC004_1201-7587_GENERIC_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 14 secs. pls help |
very tnks, i do this it is ok. |
I try with usb like in this film SETool GDFS Repair w/o TP DB2020- NEW VERSION STANDALONE - YouTube and phone s-e k550 works fine |
