02-12-2009, 06:21 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: srilanka
Member: 506398 Status: Offline Thanks Meter: 3 | k770 vodafone network lock v0.915032/UNI CARD SERIAL: 00082677 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:352384027...... CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM37 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 101 secs. plz help me............................ |
02-12-2009, 08:03 | #3 (permalink) |
Freak Poster Join Date: Apr 2007 Location: croatia
Member: 490127 Status: Offline Thanks Meter: 86 | yes you must power phone with original card or motorola test card, and then go to menu/games and run executor,phone will be dead, on setool press stop, and mark only enable preloader securyti baypass,press unlock and phone is unlocked then power phone and delete executor from games.. |
The Following User Says Thank You to josipluic For This Useful Post: |
Sony Ericsson W200i Network Lock Vodafone | mohit_kripalu01 | Sony Ericsson | 12 | 09-29-2011 09:31 |
k770 no network found | acelai00 | Sony Ericsson Hardware Repair | 4 | 02-17-2011 21:37 |
How Vodafone 411 network lock solution :::ANSWERED::: | zhuguo75 | PolarBox 3 | 7 | 05-08-2009 11:05 |
K770 Vodafone Can I Unlock? | UB_User | Universalbox | 2 | 02-05-2008 07:57 |
LOCK phone to any network Vodafone Japan Lock | maximusdecimus | UFS2 + UFS3-Tornadoflasher | 0 | 06-04-2005 07:27 |
