10-04-2011, 10:31 | #1 (permalink) |
Registered User Join Date: Apr 2010 Location: madurai thirumangalam
Member: 1286002 Status: Offline Sonork: who are you Thanks Meter: 22 | k770i dead pls help meeeee................ CARD SERIAL 00163250 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 ACTIVE CID:52 COLOR:RED can't get packet data (00000001/00000002) no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 38 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:730B108AFFFFFFFFFFFFFFFF P96 AUTH PASSED OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "D:\v1.1099\gdfs_in_ssw_format\db2020\K770_GDFS_SS W.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 27 secs. |
10-04-2011, 10:34 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Perform correct reset procedure as follows. that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area proper gdfs in ssw format 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
