08-12-2010, 13:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | K770I K700 CID52 UNLOCK help . Code: RUNNING v 1.085/UNI CARD SERIAL 000 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:3* CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):K770i Brand:3 MAPP CXC article: R8AB001 prg1201-7597_HUTCHISON_VI MAPP CXC version: R8AB001 Language Package: HUTCH_1 CDA article: 1202-4422 CDA version: R7A Default article: 1201-7603 Default version: R8AB001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R8AB001_1201-7597_HUTCHISON_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:3 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):K770i Brand:3 MAPP CXC article: R8AB001 prg1201-7597_HUTCHISON_VI MAPP CXC version: R8AB001 Language Package: HUTCH_1 CDA article: 1202-4422 CDA version: R7A Default article: 1201-7603 Default version: R8AB001 PROVIDER: MULTIPLE Network LOCKED |
08-12-2010, 15:27 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | That is an obsolete procedure and that firmware is rare Use the reset procedure go to emptyfill and repair tab select k770 go to settings tick signed mode return to emptyfill and repair tab press recovery After successful recovery untick signed mode return to empty fill and repair tab Add to firmware area %SeTool%\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw press flash That is all and it can be done in less than 30secs |
08-12-2010, 15:51 | #4 (permalink) | |
Member: 7844 Status: Offline Thanks Meter: 182 | Quote:
08-12-2010, 15:53 | #5 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Yes you can do it, it is reliable/fast/secure solution and a full unlock I think the_laser should add a box to tick with this scenario tick a box + unlock repair |
08-12-2010, 16:16 | #8 (permalink) | |
Member: 7844 Status: Offline Thanks Meter: 182 | this is what i get when i click on RECOVERY Quote:
06-25-2011, 15:13 | #12 (permalink) |
Freak Poster Join Date: May 2011 Location: ettumanoor
Member: 1587303 Status: Offline Thanks Meter: 42 | RUNNING v 1.104/UNI CARD SERIAL USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 2019 OTP LOCKED:1 CID:51 PAF:1 IMEI:35852401499416 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):K770i Brand:3 MAPP CXC article: R8AB001 prg1201-7597_HUTCHISON_VI MAPP CXC version: R8AB001 Language Package: HUTCH_1 CDA article: 1202-4418 CDA version: R7A Default article: 1201-7603 Default version: R8AB001 PROVIDER: MULTIPLE Network LOCKED SEARCH:F:\k770\R8AC001_1201-7601_VODAFONE_VI.ssw SEARCH:F:\k770\R8AC001_FS_VFE_LIVE_2_VI_RED_CID53. SOFTWARE RESTORATION FILE NOT PRESENT "R8AB001_1201-7597_HUTCHISON_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 22 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 Will backup GDFS now. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35852401499416 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM92 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 STARTING BOOTLOADER... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID: 2019 FOUND VERSION "R8AB001_1201-7597_HUTCHISON_VI" can't open file "F:\soney setool\1.104\rest\R8AB001_1201-7597_HUTCHISON_VI" LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 189 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 12/18 CARD COUNTERS: FLASH 319, UNLOCK 139 credits consumption for full signature unlock: S1 v1 4 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 6 credits ( AID 004 OFFLINE ) A1 phones 6 credits A2 phones 6 credits ( DO NOT USE FOR J108 ) by codes 4 credits current setool2 version: 1.107 Elapsed: 5 secs. SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:101000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 2019 GOT SEED:2F9F5E0E23807C781580ED79 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:wwwww PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35852401499416 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "F:\se new\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID49_ DB2020.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:[email protected] ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "F:\se new\gdfs_in_ssw_format\db2020\K770_GDFS_SSW.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35852401499416 ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "F:\se new\gdfs_in_ssw_format\db2020\K770_GDFS_SSW.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:101000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI: [email protected] CERT:RED ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "F:\k770\R8AC001_1201-7601_VODAFONE_VI.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "F:\k770\R8AC001_FS_VFE_LIVE_2_VI_RED_CID53.SOFTWA RE" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 2900 Will flash 145 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 392 secs. |
