12-11-2012, 18:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | K770i Problem when flash I need to change language on this K770i. When I flashed get this error. RUNNING v 1.1289/01.13/UNI CARD SERIAL 00057218 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35238402881470 CERT:RED ACTIVE CID: 53 COLOR: RED Model (from GDFS): K770i Brand: o2-de MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI MAPP CXC version: R8BA024 Language Package: EUROPE_2 CDA article: 1203-1887 CDA version: R5A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 20 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35238402881470 CERT:RED CURRENT CID: 53 COLOR: RED FLASH ID: 2019 Downgrading security ... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 82D719A92380806025E033D7 P96 AUTH PASSED Restarting ... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") PROCEDURE WAS STOPPED BY USER I tryed again: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35238402881470 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 2019 writing "D:\Flashes\SE\K770i\ver esta\R8BC004_1201-7587_GENERIC_VI.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks ... writing "D:\Flashes\SE\K770i\ver esta\R8BC004_FS_EUROPE_1_VI_RED_CID53.SOFTWARE" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 2820 Will flash 141 blocks ... llbug: blk write fail.fatal packet not acknowledged (3C) A1_loader_on_loaderrologue block 0 NAK Loader uploading failed,exiting Elapsed: 452 secs. Anyone can help me please ? many thanks |
12-11-2012, 19:09 | #2 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | Go to emptyboard tab Select proper model On settings, check "signed mode" Press recovery After succeful recovery On settings uncheck all Add to firmware area proper EROM (Go to eroms\db2020 and use DB2020EROM_CNV_RED53_BROWN_CID49_DB2020.ssw) Press flash Reflash phone on usual semc tab. |
The Following User Says Thank You to koperta4512 For This Useful Post: |
12-11-2012, 19:16 | #3 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote:
I solved Best regards. | |
