12-09-2008, 10:08 | #1 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 893958 Status: Offline Thanks Meter: 3 | k770i unlock problem i inditify fone, restfiles and bypass are not present , support site cant find R8AB001 prg1201-7597_HUTCHISON_VI then i still go ahead and unlock, the info shows it's done, but now fone's dead, cant turn on v0.915016/UNI CARD SERIAL: ********** Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED Model:K770i Brand:3 MAPP CXC article: R8AB001 prg1201-7597_HUTCHISON_VI MAPP CXC version: R8AB001 Language Package:HUTCH_1 CDA article: 1202-4380 CDA version: R4A Default article: 1201-7603 Default version: R8AB001 PROVIDER: 505-06 Network LOCKED RESTORATION FILE NOT PRESENT "R8AB001_1201-7597_HUTCHISON_VI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 15 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005006 0 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM30 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 Flash ID check:2019 Flash props sent ok FOUND REST FILE "R8AB001_1201-7597_HUTCHISON_VI"... UPLOADING REST FILE "R8AB001_1201-7597_HUTCHISON_VI"... can't open file "E:\SETOOL\setool\V915016\rest\R8AB001_1201-7597_HUTCHISON_VI" full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 315 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 39 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 46 secs. pls help... |
12-09-2008, 10:48 | #2 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Yes of course it dead because , there was no rest file. Quote:
The Following User Says Thank You to xerraco For This Useful Post: |
12-09-2008, 10:49 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | flash phone with setool flash file suport areea chek complatephone after flash after flashing press unlock |
The Following User Says Thank You to delchoni For This Useful Post: |
12-09-2008, 11:06 | #6 (permalink) | |
Insane Poster Join Date: Mar 2008 Location: Robinson's Metro,Philippines
Member: 719577 Status: Offline Thanks Meter: 59 | Download cid 52 sir. Quote:
The Following User Says Thank You to harungaz For This Useful Post: |
12-09-2008, 11:27 | #8 (permalink) |
Member: 719577 Status: Offline Thanks Meter: 59 | If you dont have rest file, just add the main file(the one you downloaded from support) Add the file in setool gui window, then press identify (nothing checked in settings) Rest file will be created. Clear everything first then Identify again to know if rest file creation is successful. |
12-09-2008, 11:46 | #9 (permalink) |
Member: 719577 Status: Offline Thanks Meter: 59 | Better try this first my friend. Download this file from support R8AB001_1201-7597_HUTCHISON_VI (cid 52) After dl, add in main window of setool and press identify. Rest file should be created. Clear everything, then press identify again, to see if rest file is already present.If rest file is present. Simply check enable preloader bypass in settings then press unlock repair sir. (use dcu 60) Goodluck. |
12-09-2008, 12:05 | #11 (permalink) | |
Member: 719577 Status: Offline Thanks Meter: 59 | Quote:
Try to check signed mode, enable preloader bypass and enable alternative bypass in settings then identify again. If rest and bypass present, proceed with unlocking sir. | |
12-09-2008, 12:22 | #12 (permalink) |
Member: 893958 Status: Offline Thanks Meter: 3 | yes, it was present, but due to couldnt' find match version in support site, i flashed it with this main file:R8BC004_APP_SW_1201_7590_HONG_KONG_VI_RED_CID 52_DB2020.ssw n now bypass disapeer, v0.915016/UNI CARD SERIAL: ********** Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005006 0 Flash ID check:2019 Flash props sent ok writing E:\SETOOL\flash files\k770\R8BC004 1201-7590 HK CID52\R8BC004_APP_SW_1201_7590_HONG_KONG_VI_RED_CI D52_DB2020.ssw CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing E:\SETOOL\flash files\k770\R8BC004 1201-7590 HK CID52\R8BC004_FS_HONG_KONG_VI_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:3220 Will flash 161 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 398 secs. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35852401253227 CERT:RED FLASH CID:52 COLOR:RED Model:K770i Brand:Generic MAPP CXC article: R8BC004 prg1201-7590_HONG_KONG_VI MAPP CXC version: R8BC004 Language Package:HONG_KONG CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BC004 PROVIDER: 505-06 Network LOCKED SEARCH:E:\SETOOL\flash files\k770\R8BC004 1201-7590 HK CID52\R8BC004_APP_SW_1201_7590_HONG_KONG_VI_RED_CI D52_DB2020.ssw "R8BC004_1201-7590_HONG_KONG_VI" CREATED BYPASS PACKAGE NOT PRESENT "R8BC004_1201-7590_HONG_KONG_VI.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 14 secs. |
12-09-2008, 12:47 | #14 (permalink) |
Member: 719577 Status: Offline Thanks Meter: 59 | Since we are sure that you have bypass package for R8AB001_1201-7597_HUTCHISON_VI, I suggest you flash it with R8AB001_1201-7597_HUTCHISON_VI sir. Then repeat rest file creating process and unlocking process. Goodluck sir. |
12-09-2008, 13:07 | #15 (permalink) |
Member: 893958 Status: Offline Thanks Meter: 3 | yes brother harungaz n xerraco, but as i mentioned before this version(R8AB001_1201-7597_HUTCHISON_VI) couldn't be found in support site, that's y i had to change to another ver. now i'm trying generic ver , let's see how it goees |
big big problem k770i unlock | ashokassag | SETool2 | 8 | 02-09-2009 00:50 |
K770i unlock problem | microera | Cruiser Suite | 6 | 01-26-2009 05:33 |
K770i ticker problem | justmegt | Cruiser Suite | 3 | 11-11-2008 23:29 |
k770i big problem | anumobjay | Sony Ericsson | 1 | 11-11-2008 02:08 |
K770i Reception Problem | loftus.hall | Sony Ericsson | 0 | 05-23-2008 12:01 |
