Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-23-2010, 16:29   #1 (permalink)
Member: 682203
Thanks Meter: 111
k790 whit out NETWORK HELP!!!
Hi :
im have this phone death, im repair it (whit credits) using setool3.
well now the phone power on, but dont get (cacht) network, what can i do for solve this problem ?¿
Cheers
Old 02-24-2010, 02:15   #2 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Probably a K790 flashed with a K800 or the opposite !
Do you have a 3G camera lens on the front cover ?
Read the following that might be helping you.
Max_B
Case:
Let's say you have a DB2020 phone with some GDFS issue, say you wrote K800 firmware to a K790 and now you have "no network".
Solution:You'll have to rewrite the original GDFS. Sadly, most users never back it up before proceeding with whatever operation they intended to do in the first place. This is done through the "Read GDFS" button in SETool, btw . it will produce a .bin-file named with the phones IMEI and can be found in your SETool basedir. Take good care of it.
Now, lets say you didn't back up the phones GDFS and did something to screw it up. Then you have a problem, because rewriting it with another phones GDFS will screw the security units and the phone will be bricked. Generally a bad thing, right ?.
Luckily, there is a way to solve this and the procedure is as follows:
Use only COM/UFS interfaces!
1 (Optional): Back up the corrupt GDFS (yes, even though it's corrupted, so you have a full backup just in case). Again: "Read GDFS". Move it to a safe place on your HD, this is to avoid accidentally deleting it and for avoiding confusion with all the other txt-files that will appear later on.
2: Create a scriptfile (a normal txt-file will do) with the following contents:
gdfsread:00020e5a
gdfsread:00020e48
gdfsread:00010851
gdfsread:00000006
gdfsread:0000000E
gdfsread:00000013
gdfsread:0000001C
gdfsread:00000018
gdfsread:000000AA
Now save it. Name it "readsecunits.txt" or whatever. Select the file in SETool's MISC-field and press "Write SCRIPT".
All the read units will be stored in a single file named by the phone's IMEI.
rename it as "secunitsbackup.txt" to avoid confusion
3: Apply the GDFS from a working DB2020 phone.
- Read it out from the source phone (it will be stored in the SETool basedir named by the source phone's IMEI)
- Check "Format GDFS" in "Settings" and write it to the damaged phone by selecting it in the MISC-field and pressing "Write GDFS".
If the phone in question is OTP/FLASH CID52, DO NOT CHECK "Format GDFS"
Do NOT turn the phone on afterwards.
4: Now, you'll have to write back the original units. Apply the "secunitsbackup.txt" you created by selecting it in the MISC-field and pressing "Write SCRIPT".
Old 02-24-2010, 17:45   #3 (permalink)
Member: 682203
Thanks Meter: 111
Im try u solution. DONT WORK
Im try repair GDFS whit setool + logs.
repair sucefull
still dont work.
im try put 4 bands, 850 1900 etc... not work dont cacht network.
Cheers.
Old 02-24-2010, 23:02   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
repair sucefull
still dont work.
Cheers.
Now either your gdfs files have wrong rf calibration datas, or your phones has hardware issue
Try another gdfs files !
Max_B
Old 02-24-2010, 23:19   #5 (permalink)
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,156
Hi :
Cheers
http://forum.gsmhosting.com/vbb/showthread.php?t=879592
here solution.
those 2 files attached are linked to old setool forum though. so will see if can upload them here
Old 02-24-2010, 23:34   #6 (permalink)
Member: 682203
Thanks Meter: 111
@GSMan
im apreciate ur help, whit this method, DONT WORK FOR ME !
Cheers.
Old 02-24-2010, 23:36   #7 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
@GSMan
Cheers.
You have to find working GDFS file and repeat the gdfs swap procedure !
Of course K790 has to be flashed with K790 firmware and gdfs
As K800 needs to have it's own too !
Max_B
Old 02-25-2010, 00:50   #8 (permalink)
Member: 682203
Thanks Meter: 111
@MAX_B
thanks bro for the reply im fin a K790 GDFS in bin format, im try but dont work, maby the K790 gdfs im have is corrupted ?
Cheers
Old 02-25-2010, 01:34   #9 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Not absolutely corrupted, but at least with no network calibration suitable to your hardware !
Max_B
Old 02-25-2010, 13:20   #10 (permalink)
Member: 682203
Thanks Meter: 111
What can i do ¿?
some body have a k790a GFDS working good ?
Cheers
Old 02-25-2010, 14:54   #11 (permalink)
Member: 682203
Thanks Meter: 111
im get another GDFS backup for K790a
and still have whit out service
Can body help me ?
Cheers
Old 02-25-2010, 15:08   #12 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
just tell me if the model mentioned on the back cover is K790 ?
and in software window K800?
Old 02-25-2010, 15:12   #13 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
you may try the above method mentioned by MAX_B
that was posted at mobile-files.com by LAZER and is working for me
solved many phones with this issue
Old 02-25-2010, 15:31   #14 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
i think you have some gdfs damaged issue need to rewrite security units
Old 02-25-2010, 20:32   #15 (permalink)
Member: 682203
Thanks Meter: 111
im test the solution posted by the_lazer.
whit 2 GFDS backup of k790 in bin format (im get this backups from forums)
and dont work.
Cheers
K790 with out Tp gdfs Done sajidali SETool2 2 10-06-2009 09:47
Why CANT Use USB Funtions WHIT OUT UFS OR TORNADO (OR SIMILAR) fusarista Nokia Fault Finder Box 1 11-18-2008 22:37
Boxes Whit Out Simcard Wanted !!! fusarista Wanted Products 3 05-15-2008 08:16
Sms how fix whit out flashing? Amartt Nokia Hardware & Hardware Repair 2 02-13-2007 06:28
nokia 7610 0.06 amp when connect to power suply whit out switch on morteza-icu Nokia Hardware & Hardware Repair 0 06-19-2006 12:33
Page generated in 0.29422 seconds with 9 queries
