K800 after gdfss repair v0.915029/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 INCORRECT PROCEDURE WAS STOPPED BY USER loader refused shutdown, remove and insert battery ! Elapsed: 151 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 35 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" embedded bootloader not responds ! Elapsed: 241 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR:DB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 59 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "E:\SeTool\v0.914038\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "28382240" SIGNING... Elapsed: 44 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "E:\SeTool\v0.914038\eroms\db2020\DB2020EROM_CNV_R ED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "63470173" SIGNING... Elapsed: 13 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package:TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 5 secs. SIGNED MODE (USING SERVER) Open COM port OK PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 4 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 loader header not accepted Can't load ID loader ! Elapsed: 11 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 loader header not accepted Can't load ID loader ! Elapsed: 15 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:RED FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package:TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 5 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "E:\SeTool\FLASH_FILE\SONEY_ERICSON\K800\CID52\R1G B001\R1GB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing "E:\SeTool\FLASH_FILE\SONEY_ERICSON\K800\CID52\R1G B001\R1GB001_FS_CENT_EUROPE_WI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:4500 Will flash 225 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 579 secs. |
Looks like GDFS problem again(may try to repair again with good GDFS). Please Indentify again and post here again. Try with different flash files. |
Hy....I have the same problem. Please help! here is the loog....... CFG:000000000000000 TESTPOINT REPAIR STAGE #1 STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 19 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #1 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 105 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR:DB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 59 secs. CFG:000000000000000 llbug: COM3 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\db2 020gdfs_in_ssw_format_CID49_BROWN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "36861657" SIGNING... Elapsed: 63 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\eroms\db2020\DB2020EROM_CNV_R ED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "03758761" SIGNING... Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100000100000000 ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic Trade TR MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: BALTIC CDA article: CDA102497/82 CDA version: R5A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R1CB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... subblock 019 NAK, [44C40000/00010000] Elapsed: 132 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R1CB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... SSW loading returns:0 writing "D:\Setool\Flash-uri\k800i\R1CB001_FS_EUROPE_2_WI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 554 secs. |
SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:101000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic Trade TR MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: BALTIC CDA article: CDA102497/82 CDA version: R5A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 18 secs. |
And Another try with my K800i...... what is wrong??? TESTPOINT REPAIR STAGE #1 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 65 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED llbug: COM3 open error: "Access is denied" Elapsed: 0 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... PROCEDURE WAS STOPPED BY USER TP #2 INCORRECT OR STAGE #1 NOT EXECUTED Elapsed: 48 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR:DB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 82 secs. CFG:000000000000000 llbug: COM3 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "85724201" SIGNING... Elapsed: 67 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 writing "D:\Setool\v0.915036\eroms\db2020\DB2020EROM_CNV_R ED53_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "86600542" SIGNING... Elapsed: 70 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package: TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 6 secs. CFG:000010000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED phone CID not supported in that mode Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "D:\Setool\Flash-uri\k800i\R8BF003_FS_MEDITERR_WI_RED_CID53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 1326 secs. |
dear brother can we repeiar gdfs withe out tp on setool box ? |
no brother you must need tp repeiar for gdfs |
