Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: pakistan
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks: 102
| K800 after gdfss repair v0.915029/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 INCORRECT PROCEDURE WAS STOPPED BY USER loader refused shutdown, remove and insert battery ! Elapsed: 151 secs. TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 35 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" embedded bootloader not responds ! Elapsed: 241 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR B2020_PRELOADER_FOR_SETOOL2WRITING EROM... DONE Elapsed: 59 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "E:\SeTool\v0.914038\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "28382240" SIGNING... Elapsed: 44 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "E:\SeTool\v0.914038\eroms\db2020\DB2020EROM_CNV_R ED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "63470173" SIGNING... Elapsed: 13 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:N/A FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package:TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 5 secs. SIGNED MODE (USING SERVER) Open COM port OK PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 4 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 loader header not accepted Can't load ID loader ! Elapsed: 11 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 loader header not accepted Can't load ID loader ! Elapsed: 15 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:RED FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package:TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 5 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701028092 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "E:\SeTool\FLASH_FILE\SONEY_ERICSON\K800\CID52\R1G B001\R1GB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing "E:\SeTool\FLASH_FILE\SONEY_ERICSON\K800\CID52\R1G B001\R1GB001_FS_CENT_EUROPE_WI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:4500 Will flash 225 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 579 secs. |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Deep Blue G.S.M.
Member: 225229 Status: Offline Thanks: 7
| Looks like GDFS problem again(may try to repair again with good GDFS). Please Indentify again and post here again. Try with different flash files. |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Nord Romania Age: 31
Member: 323481 Status: Offline Thanks: 158
| Hy....I have the same problem. Please help! here is the loog....... CFG:000000000000000 TESTPOINT REPAIR STAGE #1 STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 19 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #1 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 105 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR B2020_PRELOADER_FOR_SETOOL2WRITING EROM... DONE Elapsed: 59 secs. CFG:000000000000000 llbug: COM3 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\db2 020gdfs_in_ssw_format_CID49_BROWN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "36861657" SIGNING... Elapsed: 63 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\eroms\db2020\DB2020EROM_CNV_R ED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "03758761" SIGNING... Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100000100000000 ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic Trade TR MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: BALTIC CDA article: CDA102497/82 CDA version: R5A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R1CB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... subblock 019 NAK, [44C40000/00010000] Elapsed: 132 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R1CB001_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9100 Will flash 455 blocks... SSW loading returns:0 writing "D:\Setool\Flash-uri\k800i\R1CB001_FS_EUROPE_2_WI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 554 secs. |
| | #4 (permalink) |
| SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:101000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic Trade TR MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: BALTIC CDA article: CDA102497/82 CDA version: R5A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 18 secs. |
| | #5 (permalink) |
| And Another try with my K800i...... what is wrong??? TESTPOINT REPAIR STAGE #1 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 65 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED llbug: COM3 open error: "Access is denied" Elapsed: 0 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... PROCEDURE WAS STOPPED BY USER TP #2 INCORRECT OR STAGE #1 NOT EXECUTED Elapsed: 48 secs. CFG:000000000000000 TESTPOINT REPAIR STAGE #2 STARTED ChipID:9900,EMP protocol:0301 Speed:460800 ATTACH TP #2 AND PRESS "READY" Starting embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR B2020_PRELOADER_FOR_SETOOL2WRITING EROM... DONE Elapsed: 82 secs. CFG:000000000000000 llbug: COM3 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "85724201" SIGNING... Elapsed: 67 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok writing "D:\Setool\v0.915036\gdfs_in_ssw_format\db2020\K80 0_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 writing "D:\Setool\v0.915036\eroms\db2020\DB2020EROM_CNV_R ED53_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "86600542" SIGNING... Elapsed: 70 secs. CFG:000000000000000 ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package: TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 6 secs. CFG:000010000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED phone CID not supported in that mode Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 Speed:460800 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908701590294 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing "D:\Setool\Flash-uri\k800i\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "D:\Setool\Flash-uri\k800i\R8BF003_FS_MEDITERR_WI_RED_CID53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 1326 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| K800 Red Blink Repaired via TP | adnanskyland | SETool2 | 17 | 02-11-2010 17:13 |
| k800 SIM WAYS repair :) | et.com | Sony Ericsson Hardware Repair Area | 2 | 06-11-2009 12:50 |
| k800 cid49 gdfs repair successfully | gsmexpertgsmexp | DreamBox | 0 | 09-11-2008 12:29 |
| k800 after repair tp 5 lock closed | Mohsin-* | SETool2 | 10 | 08-02-2008 14:37 |
| k800 cid49 gdfs repair needed | mzsufi | DreamBox | 10 | 06-24-2008 18:55 |
