03-06-2010, 17:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: KEF_TUNISIA
Member: 681313 Status: Offline Thanks Meter: 506 | k800 cant identify v0.915057/UNI 06/03/2010 17:44:33 CARD SERIAL: xxxxxxxxxx 06/03/2010 17:44:33 Loaded 51 flash descriptors 06/03/2010 17:44:38 SIGNED MODE (USING SERVER) 06/03/2010 17:44:38 CFG:100000000000 06/03/2010 17:44:40 ChipID:9900,EMP protocol:0301 06/03/2010 17:44:40 Speed:921600 06/03/2010 17:44:41 FLASH ID:897E 06/03/2010 17:44:41 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701034036 CERT:N/A 06/03/2010 17:44:41 FLASH CID:52 COLOR:RED 06/03/2010 17:45:11 can't get packet start. 06/03/2010 17:45:41 packet not acknowledged (17) 06/03/2010 17:45:41 setGDFS_params failed 06/03/2010 17:45:41 failed to setup GDFS 06/03/2010 17:45:42 Elapsed: 64 secs. how can i fix this problem ?????? |
03-08-2010, 09:22 | #3 (permalink) |
Member: 681313 Status: Offline Thanks Meter: 506 | the log after flash 0.914020/UNI CARD SERIAL: 00042026 Loaded 51 flash descriptors SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701034036 CERT:N/A FLASH CID:52 COLOR:RED Abort all operations. set_gdfs_props failed, exiting Elapsed:7 secs. SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701034036 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\Administrateur\Bureau\SETOOL\v0.915034\fl ash file\k800i cid52\R1JE001_1250211_VODAFONE_WI.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Documents and Settings\Administrateur\Bureau\SETOOL\v0.915034\fl ash file\k800i cid52\R1JE001_FS_VFE_LIVE_2_WI_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4580 Will flash 229 blocks... SSW loading returns:0 LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed CSloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed:898 secs. SERVER SUPPORT ENABLED. |
03-08-2010, 09:35 | #4 (permalink) |
Junior Member Join Date: Oct 2004 Age: 42
Member: 85576 Status: Offline Thanks Meter: 2 | bro today i got one unit k800 with red light, try using setool3 to fix it ... follow some guide how to fix red light try to repair with p#1 and software not run nicely... few time try and still not lucky, after bored iam directly push p#2 button and run in and still not working... repair and repair again..... after tht i try on and all running smothly... wht happent ya??? |
03-08-2010, 11:11 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | you need 1credit to do reset operation : GO to emptyfille section chec use serveur click recovry stay at emptyfille section flash gdfs (ssw) flash erom GO to ssonyericson tape fullflash your phone that all enjoy |
The Following User Says Thank You to algerienbox For This Useful Post: |
09-18-2010, 13:33 | #10 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 78753 Status: Offline Thanks Meter: 35 | my k800 problem this RUNNING v1.0/UNI CARD SERIAL 00001199 USBFLASH DRIVER VERSION 02.02.00.05 Found 1 FTDI device(s). UFS #70200 READY SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801318726 CERT:N/A FLASH CID:49 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 65 secs. Found 1 FTDI device(s). ERROR [01] Found 1 FTDI device(s). UFS #70200 READY SIGNED MODE (USING SERVER) CFG:100110000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 2019 GOT SEED:553171682180DC5D1560D04D P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801318726 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801318726 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 36 secs. |
09-18-2010, 14:01 | #11 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area gdfs_in_ssw_format\db2020\K800_GDFS_SSW.ssw 8. add to firmware area eroms\db2020\DB2020EROM_CNV_RED49_BROWN_CID49_DB2020.ssw 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. skip steps 3, 4 , 5 and 6 HOW TO WORK WITH A1-BASED PHONES |
K800 Setool Identify prob | AkashBR | SETool2 | 2 | 03-11-2009 17:00 |
i´cant identify BG3 to unlock ::: SOLVED ::: | neoBIT666 | PolarBox 3 | 5 | 10-05-2008 15:07 |
K800 Cant On Bluetooth | GUDO-GSM | Cruiser Suite | 3 | 12-16-2006 20:02 |
k800 cant connect | fill | MT-BOX | 2 | 10-19-2006 20:29 |
motorola v3688 cant identify sim card | gsm-lord | Motorola Hardware Repair | 0 | 08-01-2002 18:15 |
