10-11-2008, 22:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: SWEDEN
Member: 683086 Status: Offline Thanks Meter: 15 | k800 dead after change imei |
10-12-2008, 09:19 | #3 (permalink) |
Member: 683086 Status: Offline Thanks Meter: 15 | k800 10/7/2008 7:55:23 PM v0.914037/UNI 10/7/2008 7:55:23 PM CARD SERIAL: 00063647 10/7/2008 7:55:23 PM Loaded 51 flash descriptors 10/7/2008 7:56:14 PM SIGNED MODE (USING SERVER). 10/7/2008 7:56:19 PM ChipID:9900,EMP protocol:0301 10/7/2008 7:56:19 PM 10/7/2008 7:56:19 PM PHONE IS RED RETAIL PRODUCT 10/7/2008 7:56:19 PM FLASH CID detected:52 10/7/2008 7:56:19 PM Speed:921600 10/7/2008 7:56:19 PM Flash ID check:2019 10/7/2008 7:56:19 PM Flash props sent ok 10/7/2008 7:56:19 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701700060 CERT:RED 10/7/2008 7:56:19 PM FLASH CID:52 COLOR:RED 10/7/2008 7:56:21 PM 10/7/2008 7:56:21 PM Model:K800i 10/7/2008 7:56:21 PM Brand:Sony Ericsson 10/7/2008 7:56:21 PM MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI 10/7/2008 7:56:21 PM MAPP CXC version: R8BF003 10/7/2008 7:56:21 PM Language Package:EUROPE_4 10/7/2008 7:56:21 PM CDA article: CDA102568/13 10/7/2008 7:56:21 PM CDA version: R4A 10/7/2008 7:56:21 PM Default article: cxc1250490 10/7/2008 7:56:21 PM Default version: R8BF003 10/7/2008 7:56:21 PM PROVIDER: 240-08 10/7/2008 7:56:21 PM Network LOCKED 10/7/2008 7:56:21 PM 10/7/2008 7:56:21 PM RESTORATION FILE NOT PRESENT 10/7/2008 7:56:21 PM "R8BF003_CXC1250210_GENERIC_WI" 10/7/2008 7:56:21 PM YOU MUST PERFORM FULL FLASHING 10/7/2008 7:56:21 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 10/7/2008 7:56:21 PM 10/7/2008 7:56:21 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 10/7/2008 7:56:21 PM 10/7/2008 7:56:21 PM SECURITY UNITS BACKUP CREATED. 10/7/2008 7:56:21 PM Elapsed: 6 secs. 10/7/2008 8:08:37 PM 10/7/2008 8:08:37 PM THAT ACTION IS ILLEGAL,IF YOU DOING IT 10/7/2008 8:08:37 PM FOR ANY PURPOSE, OTHER THAN REPAIR PHONE 10/7/2008 8:08:37 PM 10/7/2008 8:11:37 PM SIGNED MODE (USING SERVER). 10/7/2008 8:11:37 PM ALTERNATIVE SECURITY BYPASS ENABLED. 10/7/2008 8:11:45 PM ChipID:9900,EMP protocol:0301 10/7/2008 8:11:45 PM 10/7/2008 8:11:45 PM PHONE IS RED RETAIL PRODUCT 10/7/2008 8:11:45 PM FLASH CID detected:52 10/7/2008 8:11:45 PM Speed:921600 10/7/2008 8:11:45 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701700060 CERT:RED 10/7/2008 8:11:45 PM FLASH CID:52 COLOR:RED 10/7/2008 8:11:46 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 10/7/2008 8:11:46 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 10/7/2008 8:11:46 PM Flash ID check:2019 10/7/2008 8:11:46 PM Flash props sent ok 10/7/2008 8:11:48 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 10/7/2008 8:11:48 PM loader startup: executed 10/7/2008 8:12:07 PM loader GDFS startup: executed 10/7/2008 8:12:19 PM loader filesystem startup: executed 10/7/2008 8:12:19 PM loader unlock: executed 10/7/2008 8:12:23 PM 10/7/2008 8:12:23 PM DISCONNECT PHONE NOW 10/7/2008 8:12:23 PM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 10/7/2008 8:12:23 PM BE SURE THAT YOU SET PHONE IN "PHONE MODE" 10/7/2008 8:12:23 PM IF ASKED, INSTALL PHONE DRIVERS 10/7/2008 8:12:23 PM 10/7/2008 8:12:23 PM SEARCHING FOR PHONE, "STOP" TO ABORT 10/7/2008 8:16:58 PM PHONE FOUND AT COM31 10/7/2008 8:17:05 PM PHONE READY TO PROCEED 10/7/2008 8:17:11 PM EXECUTOR STARTED 10/7/2008 8:17:11 PM 10/7/2008 8:17:11 PM REMOVE CABLE FROM PHONE 10/7/2008 8:17:11 PM REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK 10/7/2008 8:17:11 PM THEN PRESS "READY" 10/7/2008 8:17:40 PM 10/7/2008 8:17:42 PM ChipID:9900,EMP protocol:0301 10/7/2008 8:17:42 PM 10/7/2008 8:17:42 PM PHONE IS RED RETAIL PRODUCT 10/7/2008 8:17:42 PM FLASH CID detected:52 10/7/2008 8:17:42 PM Speed:921600 10/7/2008 8:17:42 PM Trying to launch embedded bootloader... 10/7/2008 8:17:43 PM INT LDRB2020_PRELOADER_FOR_SETOOL2 10/7/2008 8:17:44 PM Flash ID check:2019 10/7/2008 8:17:44 PM Flash props sent ok 10/7/2008 8:17:53 PM FOUND: R8BF003_CXC1250210_GENERIC_WI 10/7/2008 8:17:53 PM Restore from:R8BF003_CXC1250210_GENERIC_WI 10/7/2008 8:17:53 PM can't open file "E:\صيانه 2\صيانه\صيانه\قسم البوكسات\setool\v0[1].914037\rest\R8BF003_CXC1250210_GENERIC_WI" 10/7/2008 8:17:55 PM writing E:\صيانه 2\صيانه\صيانه\قسم البوكسات\setool\db2020\k800\R8BF003_1250210_GENERI C_WI.ssw 10/7/2008 8:18:00 PM CURRENT FLASH FILE CID:52 10/7/2008 8:18:00 PM SSW uses complete hash, hash len is:9200 10/7/2008 8:18:00 PM Will flash 460 blocks... 10/7/2008 8:21:53 PM SSW loading returns:0 10/7/2008 8:21:54 PM Searching... 10/7/2008 8:21:56 PM IMEI handler determined. 10/7/2008 8:22:13 PM full sig complete. 10/7/2008 8:22:13 PM USERCODE RESET TO "0000" 10/7/2008 8:22:13 PM Searching... 10/7/2008 8:22:15 PM Firmware SIMLOCK check determined. 10/7/2008 8:22:21 PM Elapsed: 644 secs. |
10-12-2008, 09:23 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | Quote:
flash phone then it will be alive br keaelite | |
10-12-2008, 09:28 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skype:[email protected] Age: 38
Member: 469651 Status: Offline Sonork: 100.1584040 Thanks Meter: 115 | RESTORATION FILE NOT PRESENT you perfrom full flash fone |
10-12-2008, 10:08 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
before change imei u identify the phone than Security Units Backup Created in ur backup folder Select file in "misc" tab & write Script Phone will be alive ......! | |
10-12-2008, 11:10 | #10 (permalink) |
Member: 683086 Status: Offline Thanks Meter: 15 | [quote=ALi06;3739088]Use Com Cable RJ45 it cant attech via USB Yet.....! after alive all will be ok 10/12/2008 11:52:20 AM v0.914037/UNI 10/12/2008 11:52:20 AM CARD SERIAL: 00063647 10/12/2008 11:52:20 AM Loaded 51 flash descriptors 10/12/2008 11:52:35 AM SIGNED MODE (USING SERVER). 10/12/2008 11:52:35 AM Processing script "E:\صيانه 2\صيانه\صيانه\قسم البوكسات\setool\v0.914037\backup\35170701700060_10 _7_2008_7_56_21_PM.backup"... 10/12/2008 11:52:35 AM Open COM port OK 10/12/2008 11:52:42 AM ChipID:9900,EMP protocol:0301 10/12/2008 11:52:42 AM Speed:921600 10/12/2008 11:52:43 AM OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701700060 CERT:N/A 10/12/2008 11:52:43 AM FLASH CID:52 COLOR:RED 10/12/2008 11:52:45 AM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 10/12/2008 11:52:46 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 10/12/2008 11:52:46 AM Flash ID check:2019 10/12/2008 11:52:46 AM Flash props sent ok 10/12/2008 11:52:54 AM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 10/12/2008 11:52:54 AM loader startup: executed 10/12/2008 11:52:54 AM Loader refused to start GDFS services,error is:29 10/12/2008 11:52:54 AM loader GDFS startup failed, that is fatal 10/12/2008 11:52:55 AM Elapsed: 19 secs. |
10-12-2008, 11:31 | #11 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | [quote=falah1;3739175] Quote:
Goto setting tick only SIGNED CSCA Server ...& file select in "MISC" tab click write script....! B.R. ALi | |
10-12-2008, 14:47 | #12 (permalink) |
Member: 683086 Status: Offline Thanks Meter: 15 | [quote=ALi06;3739249][quote=falah1;3739175] Goto setting tick only SIGNED CSCA Server ...& file select in "MISC" tab click write script.... saem problem thanks |
10-12-2008, 14:54 | #13 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183043 Status: Offline Thanks Meter: 68 | when i flashing/completing/etc phone i got error like Code: loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 734 secs.what to do ? a: that error can be caused by different problems. lets see all of them 1. user has run "executor" application, which was not deleted after "new altbypass unlock". solution - select correct model on settings check only "use preloader security bypass". execute any operation, say : "read flash" 2. main software somehow has been damaged (cause of free tools, etc) solution - select correct model on settings check only "use signed mode". add to firmware area only main part of firmware press flash (use com/ufs or dcu60 with "2+5" keys if phone not connecting with "C" ) after that, phone should show identify normally. .... and if not.... 3. gdfs area has been damaged (bad flash ic, firmware error,etc) solution - a) install empty flash chip and do emptyboard fill procedure b) try to repair gdfs area with VERY complex testpoints c) change both mcu+flash chip from other phone good luck |
all blackberry models dead after change imei with new version | serllito | FuriousGold | 11 | 01-17-2010 16:18 |
Dead BB 8700 after changing IMEI...is it now trash? | cracker_jack | FuriousGold | 21 | 04-08-2009 12:02 |
K1 dead after change IMEI!!!!!!!! | GSMLover2010 | Ultima Box Light | 8 | 06-29-2007 14:54 |
L7 dead after chang imei | ...:::JamalMustafa:::... | Ultima Box Light | 0 | 06-29-2007 12:03 |
my 2 k800 deade after unlocked | minnu | Universalbox | 1 | 03-20-2007 22:06 |
