10-17-2008, 11:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | k800 executor run phone dead when i connect with com following error how i solove this problem PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Trying to launch embedded bootloader... phone only try no response |
The Following User Says Thank You to ikram tabassum1 For This Useful Post: |
10-17-2008, 13:04 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Bosnia, Kiseljak Age: 41
Member: 85694 Status: Offline Thanks Meter: 48 | Select preloader bypass in settings and press unlock. Connect phone with DCU-60 cable. Do not select anything else but preloader bypass in settings. BR |
The Following 2 Users Say Thank You to Luc+Luc For This Useful Post: |
10-17-2008, 13:32 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: jambuser (sarod)_swaziland_uk Age: 40
Member: 317494 Status: Offline Sonork: 1000.1984 Thanks Meter: 187 | try with fully battrey or first full flash then unlok either same problem flash with only errom |
The Following 2 Users Say Thank You to Swazi_Gsm For This Useful Post: |
10-17-2008, 14:26 | #5 (permalink) | ||
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Quote:
Bro don't click identify but unlock/repair Good Luck | ||
The Following 2 Users Say Thank You to loca|host For This Useful Post: |
10-17-2008, 14:56 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | many times posted how to recover mobile after run executer in setting tab only click on ENDABLE PRELOADER SECURTY BYPASS back main tab chose usb click unlock repair |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
11-23-2008, 09:06 | #14 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Afghanistan
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | K800 Executor Run Set Dead K800 Executor Run Set Dead Quote:
Dear Brother....If You Have Se Tool Box Open It And Select Preloader Bypass In Settings.Do Not Select Anything Else.I Think It Is The 3rd Option In The Setting. And Then Press (Unlock/Repair) Batton. Connect The Phone With DCU-60 Usb cable. Press The Hold (C) Batton If It Not Connected Then Hold (2+5) Batton Insh***** It Will Connect. And The Will Be Allrite ........... Note: When It Ok. Then On The Phone And Open The Game Floder Delete The Executor Do Not Run It Again. | |
The Following 2 Users Say Thank You to khisrow For This Useful Post: |
k800 unlock problem , There is NO EXECUTOR in phone ! | neeraj1st | SETool2 | 3 | 02-23-2010 08:10 |
k800 excutor run phone dead? | ikram tabassum1 | SETool2 | 9 | 01-27-2009 17:35 |
k610 excutor run phone dead ? | ikram tabassum1 | SETool2 | 3 | 11-17-2008 15:56 |
k550 cide 53 EXECUTOR has run PHONE DEaD | zakiyyboss | SETool2 | 19 | 10-07-2008 14:18 |
My phone dead after running SEUS | airplane_vn | KULANKENDI Server | 41 | 05-22-2007 10:40 |
