03-29-2009, 10:59 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 993362 Status: Offline Thanks Meter: 18 | k800i after on phone show SE logo then light blinking see log & post what i do v0.915034/UNI CARD SERIAL: 00077060 Loaded 51 flash descriptors Connecting to UFS... Found 2 FTDI device(s). UFS #99281 READY Closing UFS at your request. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35471601567866 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1JC002 prgCXC1250210_GENERIC_WI MAPP CXC version: R1JC002 Language Package:M_EAST_N_AFR CDA article: CDA102239/43 CDA version: R15A Default article: cxc1250490 Default version: R1GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. |
03-29-2009, 11:20 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Hello u have GDFS area corupted u should use Tp method look here Model (from GDFS):K700 Thanxs |
The Following User Says Thank You to mujahid_ali For This Useful Post: |
03-29-2009, 12:27 | #4 (permalink) |
Member: 547967 Status: Offline Thanks Meter: 653 | Try this Bro 1. go to emptyboard fill & repair 2. select any db2020 model 3. press "TP STAGE #1". read "instructions" and execute them. or (3a. check the box between the TP STAGE 1 & 2 in order to automatically proceed to tp sage 2 if your TP #1 is ok) 4. press "TP STAGE #2". read "instructions" and execute them. 5. now the the phone is cid49 brown 6. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format === now write db2020gdfs_in_ssw_format_CID49_BROWN.ssw"==== 7. if flashing went fine, flash db2020 erom with needed CID = since my otp cid is 51 so i used "DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw", === === warning;=== example if your otp cid is CID51 === do not write erom with lower cid ex..k800_erom_cnv_RED49_BROWN_CID49_DB2020.ssw because you cant flash the phone it gives you an error when you perform fullflash 8. phone now retail and repaired. fullflash phone as usual. Here is Easy TP for K800 |
N95 Only Show Nokia Logo Then Off | Sonu Jawed | Nokia Base Band 5 ( BB-5 ) | 15 | 12-01-2010 11:27 |
5130x show nokia logo then promt show white screen | aukonline | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-20-2010 19:34 |
N95 Only Show Nokia Logo Then Off | ..:::Gsm india:::.. | Nokia Hardware & Hardware Repair | 4 | 05-28-2009 05:47 |
x700 show only logo then off | ***MALIK*** | NSPRO | 1 | 05-16-2009 14:51 |
w900i on the phone display sonyericsson logo then white screen | lewislulch | Cruiser Suite | 5 | 05-07-2009 07:51 |
