03-31-2010, 13:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | K800i CID 49. not upgrading to CID 52 SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35342701892484 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Processing script "C:\setool\version 20\script\DB2020_CID49_51_to_CID52_OLD.txt"... Writing GDFS var 0001/084E/010B Phone detached Elapsed: 38 secs. SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35342701892484 CERT:N/A FLASH CID:49 COLOR:RED Model (from GDFS):K800i Brand:T-mobile MAPP CXC article: R1CF001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1CF001 Language Package:T_MOB_INT_A CDA article: CDA102511/12 CDA version: R12A Default article: cxc1250490 Default version: R1CF001 PROVIDER: 234-30 Extended LOCKED RESTORATION FILE NOT PRESENT "R1CF001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. |
05-14-2011, 13:32 | #5 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Spain Barcelona
Member: 1558861 Status: Offline Sonork: aftabmiraj15 Thanks Meter: 4 | also DB2020 cross CID flashing is not suported by any tool cross CID flashing means that if you have phone CID49 you must use flashfiles for CID49, if you have phone CID51 you must use flashfiles for CID51 etc BR |
k810 cid 49 how to upgrade to cid 52 or 53 ? | Brother Hui | Sony Ericsson Hardware Repair | 6 | 12-16-2009 09:08 |
upgrate cid 49 and 51 to 52 | beni b | Sony Ericsson | 9 | 11-24-2007 06:14 |
K610i error CID 49 & 51 to CID 52 | DonJose | MT-BOX | 2 | 07-31-2007 23:02 |
K608i CID 49 Not Supported :( | gsavv723 | SonyEricsson (USB-Smart) | 5 | 10-16-2005 21:34 |
K608 CID 49 not supported yet?!?! | Raklm | Cruiser Suite | 3 | 10-14-2005 06:36 |
