04-26-2010, 15:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | k800i dead check log Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701434719 CERT:N/A FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35342701039440 Model (from GDFS):K800i Brand:Generic Trade MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1KG001 Language Package: EUROPE_1 CDA article: CDA102568/10 CDA version: R1A Default article: cxc1250490 Default version: R1KG001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 12 secs. tell me wht i do now i have flash with other firmware but still dead |
04-27-2010, 08:07 | #3 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Pakistan Age: 40
Member: 1074634 Status: Offline Sonork: 100.1583894 Thanks Meter: 241 | 1.its need to recover 2..press recover tab and press 2+5 3.write GDFS and epprom and click flash button only signed mood 4.now attach set with prassing C and identy 5.full flash the set. may be solve your problem |
04-27-2010, 09:53 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
CID 50,51,52,53 reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. from FAQ | |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
3200 LOGS 1600 Picture Messages | GM | GSM Mobile Links | 0 | 02-09-2001 14:06 |
check out my FREE large gsm soft site | LaLGsm | GSM Mobile Links | 0 | 01-16-2001 04:36 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
