05-12-2010, 22:40 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 694717 Status: Offline Thanks Meter: 4 | k800i Dead help CARD SERIAL 00121156 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 38 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:53 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 46 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 73 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:53 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 148 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 49 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:53 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 119 secs. SIGNED MODE (USING SERVER) CFG:100111000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "G:\k810i\K800i-CID-RED-53-R8BF003-VOD2-SETOOL\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "G:\k810i\K800i-CID-RED-53-R8BF003-VOD2-SETOOL\R8BF003_FS_VFE_LIVE_2_WI_RED_CID53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal |
05-13-2010, 09:42 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | * select k800 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 k800 after successful RECOVERY * switch to empty board tab * select k800 * add k800_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 k800 * flash with red 52 firmware check on settings signed mode "customize phone after flash" * DONE. |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-15-2010, 19:59 | #4 (permalink) | |
Member: 694717 Status: Offline Thanks Meter: 4 | Quote:
SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\yasso\Desktop\K800i-CID-RED-49-R1CF001-AR-SETOOL\r1cf001_CXC1250210_GENERIC_WI.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 12 secs. i need help | |
05-15-2010, 20:13 | #5 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | "HDR block not accepted,error: 19" means the color or the cid are mismatching with those in the phone from here you go * untick all settings * switch to empty board tab * select k800 * add k800_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 k800 * flash with red 52 firmware check on settings signed mode "customize phone after flash" |
The Following User Says Thank You to Aishur For This Useful Post: |
05-15-2010, 21:08 | #8 (permalink) |
Member: 694717 Status: Offline Thanks Meter: 4 | its sime proplem SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "G:\k810i\K800i-CID-RED-52-R8BF003-AR-SETOOL\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "G:\k810i\K800i-CID-RED-52-R8BF003-AR-SETOOL\R8BF003_FS_M_EAST_N_AFR_WI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 476 secs. |
05-15-2010, 21:09 | #9 (permalink) |
Member: 694717 Status: Offline Thanks Meter: 4 | SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:52 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 87 secs. |
05-15-2010, 21:15 | #11 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
05-15-2010, 21:18 | #12 (permalink) |
Member: 694717 Status: Offline Thanks Meter: 4 | SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102609161 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "G:\pro_box\v1.01\gdfs_in_ssw_format\db2020\K800_G DFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 8 secs. |
05-15-2010, 21:18 | #13 (permalink) | |
05-15-2010, 22:53 | #15 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | check if you can connect the phone through "C" instead of 2+5 if yes, retry to complete the phone (flash without adding firmware), use "C" if no, the erom is damaged so redo the same process as above (reset ) If none can help, check the pcb and rehot a bit |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
