Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks: 51
| K800i embedded flashloader not responds ! Hi,i want to unlock K800i Flash CID52......but stop at embedded flashloader not responds ! How i can solve this problem.thanks SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701270995 CERT:N/A FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: R1CB001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1CB001 Language Package:EUROPE_1 CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1250490 Default version: R1CB001 PROVIDER: 000-00 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 7 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701270995 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM36 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 184 secs. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| Full Flash Phone & than Try TO Unlock before unlocking tick 1 more options preloader bypass check & Post Logs best regards ALi |
| | #3 (permalink) |
| Moderator ![]() Join Date: Dec 2006 Location: Pakistan " Karachi " and Dubai
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks: 208
| SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM36 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" After this first press ready then connect battry or cable |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 391664 Status: Offline Sonork: 100.1580390 Thanks: 228
| if u are facing this problem again after flashing just used this version v0.914028 old method BR MAPLE GSM(UMER) Last edited by maplegsm; 08-19-2008 at 11:27. |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: tunisia Age: 34
Member: 546406 Status: Online Thanks: 530
| use 0.914037 is the best you must have bypass package for this phone **and follow procedure finally after unlock you must delete "executor" on games if phone is "dead" you must reflash with same firmware with main.ffs only |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2005 Age: 36
Member: 126612 Status: Offline Thanks: 5
| Actually your problem the way i see it mate is that you are using 2+5 to boot and detect phone for USB !! Hold the "c" button instead !!! Boot rom is only for serious firmware recovery !!!!!!1 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| k800i testpoint embedded flashloader not responds | Andriey | SETool2 | 6 | 02-09-2009 23:21 |
| k800 embedded flashloader not responds ! | hackgsm | SETool2 | 1 | 10-04-2008 16:29 |
| W880i - embedded flashloader not responds ! | eduardo000 | SETool2 | 2 | 08-29-2008 09:05 |
| k550im embedded flashloader not responds ! | leader_gsm | SETool2 | 4 | 08-06-2008 23:50 |
| Help me !Embedded Flashloader Not Responds | vnsun | Sony Ericsson | 0 | 12-24-2007 02:50 |
