09-26-2008, 11:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | K800i Flashing problem verify block error 01 ? help plz ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:359*******88990 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing F:\backup\meeji\MOBILE\SonyEricsson\Firmwares\k800 \K800_R1JG001_MAIN_GENERIC_WI_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... verify block error 01, [44150000/00010000] Elapsed: 19 secs. Phone has white screen, just trying to flash it.. any suggestions. many thanks |
09-26-2008, 11:18 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | nothing will help. sombody played hard with phone and installed wrong flash ic or made incorrect emptyboard fill procedure. the only cure - change flash chip and repeat emptyboard procedure (or, if flash is used - repair phone with testpoint) |
09-26-2008, 13:24 | #9 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
K550i Flash says : verify block error 01, [45E90000/00010000] | trantam_web | Sony Ericsson | 10 | 01-29-2010 03:47 |
verify block error 68/01, [44950000/00010000] | kapilgupta | Sony Ericsson Hardware Repair | 0 | 08-29-2009 14:41 |
K800i camera error need help plz. | msantar | Sony Ericsson Hardware Repair | 5 | 08-12-2008 07:36 |
verify block error on w300 | nost | SETool2 | 0 | 12-13-2007 18:48 |
