08-06-2010, 04:31 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: ENGLAND Age: 53
Member: 30709 Status: Offline Thanks Meter: 45 | k800i please wait.... Flashed it with k810i cid 52, with signed, enable and cust. forgot you don't need enable. When completed it shows please wait, black back ground please wait in middle and purple bar at bottom. Tried to reflash it with k800i but error:19-wrong cid, so upgraded cid to 52 by writing in script. Flashed it with k800i - still please wait, as above. Put in recovery mode and flashed gdfs, erom and full flash k800i cid 52. But still please wait... Help any idea's out there??? FULL log display- RUNNING v 1.07/UNI CARD SERIAL 000***** USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED Model (from GDFS):K800i Brand:Generic Trade UK MAPP CXC article: R1GB001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1GB001 Language Package: EUROPE_2 CDA article: CDA102511/2 CDA version: R10A Default article: cxc1250490 Default version: R1GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SEARCH:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k810i\K810_R8BA024_FS_CENT_EUROPE_RED52\K810 _R8BA024_FS_CENT_EUROPE_RED52.fbn SEARCH:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k810i\K810_R8BA024_MAIN_GENERIC_SM_RED52\K81 0_R8BA024_MAIN_GENERIC_SM_RED52.mbn RESTORATION FILE NOT PRESENT "R1GB001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k810i\K810_R8BA024_FS_CENT_EUROPE_RED52\K810 _R8BA024_FS_CENT_EUROPE_RED52.fbn" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 HDR block not accepted,error: 19 Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM20 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 STARTING BOOTLOADER... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID: 2019 FOUND VERSION "R1GB001_CXC1250210_GENERIC_WI" can't open file "C:\Program Files\SETOOL2G\rest\R1GB001_CXC1250210_GENERIC_WI" writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k810i\K810_R8BA024_FS_CENT_EUROPE_RED52\K810 _R8BA024_FS_CENT_EUROPE_RED52.fbn" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k810i\K810_R8BA024_MAIN_GENERIC_SM_RED52\K81 0_R8BA024_MAIN_GENERIC_SM_RED52.mbn" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 603 secs. CFG:001000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 8 secs. CFG:001000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 ACTIVE CID:51 COLOR:RED Model (from GDFS):K700 <= (STRANGE) MAPP CXC article: R8BA024 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BA024 Language Package: EUROPE_2 CDA article: CDA102511/2 CDA version: R10A Default article: cxc1250490 Default version: R1GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SEARCH:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_1250210_GENERIC_WI.ssw SEARCH:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_FS_EUROPE_1_WI_RED_CID52 .ssw RESTORATION FILE NOT PRESENT "R8BA024_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 31 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 STARTING BOOTLOADER... PROCEDURE WAS STOPPED BY USER can't get packet start. FLASHLOADER NOT RESPONDING Elapsed: 34 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 STARTING BOOTLOADER... can't get packet start. FLASHLOADER NOT RESPONDING Elapsed: 39 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 STARTING BOOTLOADER... PROCEDURE WAS STOPPED BY USER can't get packet start. FLASHLOADER NOT RESPONDING Elapsed: 65 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT Can't read IMEI (COM24) PHONE FOUND AT COM24 PHONE READY TO PROCEED PROCEDURE WAS STOPPED BY USER Phone not responds to AT #3, retry 0 There is NO EXECUTOR in phone ! Elapsed: 142 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Processing script "D:\phone stuff\6 SETOOL\DB2020_CID49_51_to_CID52_OLD.txt"... ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed Writing GDFS var 0001/084E/010B Phone detached Elapsed: 37 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 <=AGAIN MAPP CXC article: R8BA024 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BA024 Language Package: EUROPE_2 CDA article: CDA102511/2 CDA version: R10A Default article: cxc1250490 Default version: R1GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BA024_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_FS_EUROPE_1_WI_RED_CID52 .ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 476 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 41 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 PROCEDURE WAS STOPPED BY USER packet not acknowledged (24) ReadOTP failed OTP read error ! Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed USERCODE RESET TO "0000" Elapsed: 25 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 14 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 10 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 8 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 3/27 CARD COUNTERS: FLASH 187, UNLOCK 102 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 2019 GOT SEED:C352BE092180936415B0AD52 P96 AUTH PASSED OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "C:\Program Files\SETOOL2G\gdfs_in_ssw_format\db2020\K800_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 33 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 ACTIVE CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 66 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "C:\Program Files\SETOOL2G\eroms\db2020\DB2020EROM_CNV_RED52_B ROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 31 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 2019 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package: TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 37 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\r1cf001_CXC1250210_GENERIC_WI[1].ssw\r1cf001_CXC1250210_GENERIC_WI.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701338651 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\phone stuff\6 SETOOL\SETOOL FLASH FILES\k800i\cid52\R8BF003_FS_EUROPE_1_WI_RED_CID52 .ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4420 Will flash 221 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 475 secs. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Sp unlocking sim - if you can get or sell please let me know | andrew bennett | Wanted Products | 1 | 09-24-1999 08:43 |
