02-23-2011, 04:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | k800i software problem! please help! SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:14E0C75D2380EC76952312DA P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 45 secs. after recovery identity____ SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 77 secs. writing gdfs_________ SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\RANA\Desktop\v1.104\gdfs_in_ssw_format\db 2020\K800_GDFS_SSW.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 35 secs. writing Erom_______ SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\RANA\Desktop\v1.104\eroms\db2020\DB2020ER OM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 19 secs. identity after writing erom CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:52 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package: TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. when customizing________ SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed FS startup failed,error is 03 [ 1] loader fs startup failed, that is fatal Elapsed: 29 secs. what can i do for this??? please help! thanks |
02-23-2011, 05:03 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: KERALA / SWAMI SARANAM Age: 36
Member: 1334005 Status: Offline Sonork: 100.1601457 Thanks Meter: 362 | hello brother first u recovery then unlock the phone select sign mode then write gdfs ssw & erom ok try it 1000% okkkkkkkkkkkkkkkkkkkk |
02-23-2011, 05:57 | #4 (permalink) | |
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | Quote:
say about details__________ by ur system this is log___ SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Unlock DONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\RANA\Desktop\v1.09\gdfs_in_ssw_format\db2 020\K800_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 31 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\RANA\Desktop\v1.09\eroms\db2020\DB2020ERO M_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 14 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:52 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: 2007-12-13 16:25 CXC1722434_TEMS MAPP CXC version: R2B Language Package: TEMS CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1722435 Default version: R2B PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "2007-12-13_07-12-13 16:25 CXC1722434_TEMS" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35812457893218 ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 13 secs. | |
02-28-2011, 09:09 | #8 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1525159 Status: Offline Sonork: NP Thanks Meter: 1 | contact me |
