07-05-2010, 08:34 | #1 (permalink) |
Registered User Join Date: Feb 2006 Location: tagum,davao philippines
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | k800i why cid 15 pls help CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID: 897E OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 ACTIVE CID:53 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BA024 Language Package: APAC CDA article: CDA102511/2 CDA version: R2A Default article: cxc1250490 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BA024_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED recovery SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:5D36AFD1FFFFFFFFFFFFFFFF P96 AUTH PASSED OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 empty refill CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 ACTIVE CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E PHONE CID NOT SUPPORTED IN THAT MODE please any help......... |
07-05-2010, 10:25 | #2 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 646256 Status: Offline Thanks Meter: 63 | Quote:
Q: i have emptyboard phone. how to convert it to normal ? A: warning ! steps are important. for db2000/db2010: 1. go to empty board 2. select needed model 3. select needed cid (select cid49 for all "modern" phones, select cid36 for "old" phones (k700,k500,s700,k300), select cid29 for ancient z1010. 3. press recovery 5. if board is totally empty (new flash chip), select needed gdfs_in_ssw_format 6. select respective EROM (if phone need EROM) from EROMs folder fill IMEI number, check WRITE OTP (it can be done only once, be careful) 7. press flash phone now normal retail and can be serviced as any other phone. for db2020. 1. go to empty tab 2. select any db2020 model 3. select cid49 (that is REQUIRED) 4. press recover 5. if board is totally empty (new flash chip), select needed gdfs_in_ssw_format 6. select respective EROM (better use k610_erom_cnv_brown2red.cry - works for any phone) 7. fill IMEI number, check WRITE OTP (it can be done only once, be careful) 8/ press flash phone now normal retail and can be serviced as any other phone. | |
The Following User Says Thank You to KHD19 For This Useful Post: |
07-05-2010, 11:49 | #3 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | thanks sir i followed the above method but during flashing gdfs theres an error phone cid not supported in that mode |
07-05-2010, 11:50 | #4 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 ACTIVE CID:49 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE |
07-05-2010, 12:05 | #5 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N Fetching phone data from OTP OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 Recovery succefull. Reflash phone now |
07-05-2010, 12:06 | #6 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | my problem is this OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 how can i repair this....thanks for help ill wait masters ..... |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
